Checklist of things to replace when taking manifold off
Okay I'm gonna be pulling my intake manifold off to swap it for one designed for my car. (1993 and below uses butterfly valves, 1994 does not)
Things to replace: -manifold gasket -plenum gasket -throttle body gasket -pcv valve -all vacuum lines under manifold (anyone know the size hoses to get?) -wouldn't kill me to change knock sensor... 140k miles, should i change it? Anything else I should look into changing while the manifold is off? |
EGR is getting removed, that turd stopped working a while ago. Yeah there's a ton of water lines behind there.... ugh makes me want to just pay someone to do it
I know they're a waste, that's why im putting the manifold on that doesn't have them lol |
