![]() Join Date: Feb 2002
ISIS True 3" Turbine Outlet - ** New Product **
*ISIS 3" Turbine Outlet O2 Housing - Nissan SR20DET S13/S14
![]() ![]() ![]() *ISIS 3" Turbine Outlet O2 Housing - Nissan SR20DET S13/S14 *NEW [ IS-O2-SR3IN ] - Enjuku Racing - Performance Parts and High Quality Fabrication - $129.99 ISIS [I-sis] 3" Turbine Outlet O2 Housing - Nissan SR20DET S13 T25/S14 T28 or GT Series Turbo ISIS Performance brings you the first True 3" Turbo outlet. Every other turbine outlet necks down, This new design from ISIS Is a higher flowing true 3" outlet. Turbo Outlets increase exhaust flow and free up Horsepower. Great bang for the buck upgrade. Includes all gaskets and hardware required for install. This Specific Outlet has been double welded on the outside and inside to prevent cracking
![]() Join Date: Feb 2012
I bought this product and it is definitely NOT "true" 3 inch. Measure it. It is 2 3/4" and uses a70mm gasket. A 3"won't work. Not to mention noone even makes a down pipe that is not necked down at the front so it doesn't make any difference. When i spoke with Ken he said that him self. I definitely support innovative companies that do their own thing but why is this listed as 3"? It is definitely the largest I've seen but if you spend $20 on a high quality gasket like i did (vibrant brand) it will not work. 2 3/4" works perfect.
It looks like you may have been shipped one of the normal ones. I just went out back and measured the "3"" ones and the outlet flange is exactly 3".
Please give us a call on Monday with your order # and name so we can get you taken care of. Or feel free to email me [email protected] and i will personally take care of you thanks Ken
It was the two piece elbow with the weld around the middle. Looks to be the correct one, a 3" gasket just would not work. Not trying to bash your product at all. I still do business with you to date. I have already used your product so an exchange is not necessary. I just wanted to state that what received was not "true 3 inch." If you would manufacter a matching downpipe (since there are none that do not bottle neck) I would gladly purchase this setup again. Just seems pointless when the restriction is still there, just farther from the turbo. Either way, keep up the good work Ken!
Do you happen to have any pictures of the gasket and O2?
Here is a picture of the O2 outlet I just measured. The flange is a tad over 3" and the inner diameter of the pipe is a tad under by about 1/9-1/16th. So, i guess you could say its not a "true 3". ![]() As for a 3" downpipe that does not neck down, i have seen a few online. They are mostly no name brands. Let me know if you have any issues with what you received and we will take care of you in any way possible thanks Ken
That's wierd, mine just seemed to be undersized I guess? Either way, the welds were great and after I found the correct gasket it worked great. +1 for Enjuku
Ok.. let me know if you ever need anything and i will take care of you
thanks!! Ken
Thanks Ken. Taking care of customers like this is why I do business with Enjuku. I will be ordering another outlet as well as a TiAl wastegate from you this week. Would you mind measuring your regular Isis outlet for me. I'm thinking of purchasing it depending on the size of the exit. Also, for everyone wondering, what is the warranty against cracking on these Isis outlets? I know it rarely happens, but for a lot of people a warranty against cracking can be the deciding factor of their purchase. Thanks again Ken.
Anybody have this that can describe the figment. It says requires slight clearancing of bell housing or flange on enjuku. Not sure what that's means. Anybody have to make adjustments and what turbo were you running if you did or didn't.
4 SALE intercooler mafs valvecover rep fn01rc http://tinyurl.com/jmaxzilvia |
Anybody? Trying to get this or the old version today.
#17 |
Clearance of the bellhousing would just mean grinding a little metal off it to avoid rubbing and breaking of the elbow (helps prevent cracking)
No biggie....and a small price to pay for increased performance and spool.. Ch Sent from my SM-N900V using Tapatalk |
