Help replacing bulb next to headlight (corner light)
I need to replace the light bulb next to the headlight. Its the corner light (manual says its the clearance light). Note this is not the side marker light. Its right next to the head light. What do i need to do to replace it. I was told to remove the cover by taking out a screw then I would be able to wiggle or pivot the cover out but its not coming. I have pulled on plastic cover very hard but the back part is not budging and I'm worried i am going to damage something. This is on a '95 240sx. Anyone dealt with this before and can help.
thank!! |
![]() Join Date: Feb 2002
Yea, the corner lamp is a bitch to take out. All I can say is....unscrew the corner lamp from the headlight, then firmly grab the corner lamp. Now this might sound weird...but get as close as you can to your car and firmly (but gently) pull the corner lamp towards you. Don't wiggle it or pull at an odd angle....because you will break the pivot holder (made up word).
make sense? ![]()
Goals are dreams with a deadline. L.H.O.O.Q. |
ok so basically pull very hard straight out, like if i am standing at the front corner of the car. If i manage to get it out and able to replace the bulb do I just push the cover in very hard? I know these maybe stupid questions but I have worked on this for an hour now and I'm frustrated!! I tried taking the other one out but couldn't get it to come out either plus I lot the screw.
Thanks |
You don't use as much force installing the corner lamp as you do removing it. Just gently push back into place until you hear a "click".
You can get a replacement screw at Home Depot. ![]()
![]() Join Date: Sep 2002
And AMBER BULBS!!! They look great in an S14, that's whst I have in mine, don't you too, GT?
#6 | |
= My day
#7 | ||
#9 | |
![]() Join Date: Jan 2002
me and all my friends here in hawaii dont use the amber lights for our corners....we use either the raybrig or piaa honey bee yellow lights so that our corners arnet amber but instead are bright yellow
95 240sx SE,custom dual apex n1, 17" rims,tanabe sustec front STB,nismo rear STB,intake,tanabe sustec pro coilovers,autometer guages, soon to have stock 97-98 side skirts and rear mud guards and bomex drift wing |
#11 | ||
#15 | |
![]() Join Date: Jun 2007
How did you even find this thread?
