93 s hatch no start after rebuild
car wont start after rebuild
all new fuses and relays checked new coil dizzy from runnin car new coolant temp sensor maf from running car ecu from running car 3 different engine harnesses pulled injectors/ no leaks plugs black and wet tested ignitor new fuel filter new walbro255 pump new tomei fuel regulator new wires, cap, rotor new tps and recalibrated 0mi on motor yet ka24de drained and refilled fuel tank |
to start now I have to pump gas pedal and itll start turning over faster eventually to start and sound great a few seconds and then just like it drops a cylinder or something and if pedal is blipped on cable return it picks rpms back up to around 1700 until feels like timing falls out and have to play with pedal to wake back up..if a lot of pedal applied at once it stalls immediately
i have a similar problem but mine wont crank at all. no idea why.
new harnesses, battery, starter works fine and all the lights/horn/interior stuff works fine but when the key is turned nothing happens. please help! |
ok so i know that this is not going to be typical of all 240 owners but in my case what caused the problem was that the previous owner had bypassed the clutch switch completely and instead of having the clutch relay next to the battery he'd removed the relay assembly and joined the main wires via a 10 amp fuse. replacing that, it fired up just fine. the only thing now is that i'll have to re-wire the switch back up if i ever want to be free of worrying if the fuse has blown or not :/
Holy shizz so after that last comment I figured id check my clutch switch anyway and it appears to have had the plug completely cut off..there is a green/red stripe and green/black stripe wire hangin is that for the switch and do I really need it?
