Old 10-04-2016, 07:24 PM   #151
rbs14kouki
rbs14kouki's Avatar
I'm using the Mazworx bellhousing for mine, along with an OSGiken TS2BD twin disc clutch. I ordered the sleeve that OsGiken recommends to use for s13, with the stock s13 trans, since the Mazworx bellhousing uses the sr20 trans fork/ball/sleeve etc normally. I'm hoping this will give me the correct gap, but we will have to see when I get it all put together.
Also in the OsGiken instructions they say you have to shave 4mm away from the shaft inside the bellhousing that the throwout bearing sleeve slides on, or else it will hit the pressure plate of the clutch. I'm not sure if I'm going to have to do the same thing to the Mazworx bellhousing but I really hope not. I'm going to try to install the clutch, and then the bellhousing by itself and see if it hits the pressure plate. If not I'm hoping that the Sleeve I ordered gives me the 8mm gap between the bearing and pressure plate that they recommend.
edit- If you want part numbers for the sleeve/bearing I ordered for my setup for archiving purposes I could look them up when I get home.
8mm is .315in
On the setup i just did . I was aiming for .200in but it the end the machinist that did my spacer wasnt 100% on my specs ... we ended up with .300 air gap and its perfect on our set-up
We Installed everything and he drove away . I Was happy i didnt had to fuck around to make it work like the first setup i did ... do it once , do it right
AV FABRICATION
Built thread sr20vet s14
#/f/showthread.php?t=535574
Old 10-04-2016, 08:12 PM   #152
TheRealSy90
TheRealSy90's Avatar
Yeah so I guess I'll have to wait and see if the maz housing uses the same parts and requires the same mods as the sr20 housing for the giken twin disc.
Such a good signature.
Old 10-06-2016, 09:14 AM   #153
rbs14kouki
rbs14kouki's Avatar
If you have a Vernier caliper you could double check with some mesurments and not wait and loose time if your missing parts !
I could help you out
AV FABRICATION
Old 10-06-2016, 09:14 PM   #154
TheRealSy90
That I do not have, I have a measuring tape?
Old 10-20-2016, 12:29 AM   #155
rbs14kouki
rbs14kouki's Avatar
my Gktech swaybar just got in last week and WOW !!! Quality of there parts is way over my expectation everytime
my car is schedual to go at AvFab for the cage and chassis prep in the next month ... things will go fast once its over there
AV FABRICATION
Old 11-06-2016, 07:18 PM   #156
b.series
b.series is making a name for him/her selfb.series is making a name for him/her selfb.series is making a name for him/her self
Why do you need to use a solenoid relocation if you have Custom made VVl lock pin vvl killer? isnt the solenoid used to lock the pin at your desired RPM? Why wouldn't you just block off the holes? Still trying to learn about this head swap before I get it.
b.series is offline   Reply With Quote
Old 11-07-2016, 09:22 AM   #157
scottie
scottie's Avatar
rbs14kouki - Will you please post how the sway bar endlinks attach to the lower control arm? I am very interesting in this setup. I have the GKTech FLCA's so I assume this will work with them.
IG: @scotheocelot
Old 11-07-2016, 06:48 PM   #158
rbs14kouki
rbs14kouki's Avatar
ill keep the mazworx plate in the back of the head but all the holes are gona be blocked ... im not gona run the vvl relocation kit .
AV FABRICATION
Old 11-07-2016, 06:50 PM   #159
rbs14kouki
rbs14kouki's Avatar
if you look at the flca ...
on the right of the tie rod stopper ... you have 3 holes ! the endlinks bolts in there ... i guees they make 3 position for different size swaybar !?!? that im not sure
AV FABRICATION
Old 11-07-2016, 07:21 PM   #160
scottie
scottie's Avatar
I figured that might be where it mounts. Can you post the endlinks that come with the bar at some point?
IG: @scotheocelot
Old 11-08-2016, 08:12 AM   #161
TheRealSy90
Probably three positions based on how far you extend the lca outwards.
Old 11-10-2016, 02:52 AM   #162
rbs14kouki
rbs14kouki's Avatar
they dont give a end link with the swaybar ... ill just by a set of sikky or something like that (pillowball) to finish the set-up
AV FABRICATION
Old 01-18-2017, 05:11 AM   #163
AscendaShogun
AscendaShogun's Avatar
AscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the rough
This is a rad thread, years of building for assurity. Cant wait to see it on track however!
Give us some more updates!
SuperRadDriftyFranz
'88 S13 Silvia
decrepit teenage shitsleds
Originally Posted by LoSt180 View Post
"Cut my springs, car is bouncy, will a camber kit help?"
AscendaShogun is offline   Reply With Quote
Old 04-08-2017, 04:50 PM   #164
rbs14kouki
rbs14kouki's Avatar
here is an update in the car . slow process sorry guy's
The cage is in process at #avfabrication . We made good progress in the last 2 weeks even tho we only work 4hours a week on the car .
With the shop almost at full capacity and with big project cars, its just normal that we only work on my car on the sunday's ... clients come first and leave pleased from the shop , that's our number one goal .
Next step is to had some more bracing and then drop the cage to weld the top . After that we attack the transmission tunnel and seat position before finishing the rest of the cage .
AV FABRICATION
Old 04-09-2017, 07:56 AM   #165
The Real Keith
The Real Keith is an unknown quantity at this point
It exam
The Real Keith is offline   Reply With Quote
Old 04-09-2017, 06:46 PM   #166
Will.
Will.'s Avatar
Will. is an unknown quantity at this point
awesome build
Will. is offline   Reply With Quote
Old 04-17-2017, 08:52 PM   #167
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
People are getting $430 for P12 cams? Jeeze, I sold mine for $300
Nice build, similar to mine (VE head, 350 trans, lots of GKTech parts)
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 04-28-2017, 10:47 PM   #168
rbs14kouki
rbs14kouki's Avatar
Yeah since nissan doesnt make them anymore they go for more then that now ... i got lucky with my set a 400$ if i ever change its for some 184st but i make my engin start and run before upgrading again hahahajhaha
AV FABRICATION
Old 11-23-2018, 01:54 AM   #169
rbs14kouki
rbs14kouki's Avatar
I just updated my first post to what the list of parts that are on the car as of today ... i will update with pictures soon
I know my built is taking way to long but a separation with my ex. Selling my house loosing shit tone of money just to get a new start . It got me good but im back on my feet now and ready to finish this once and for all
AV FABRICATION
Old 12-05-2018, 08:17 AM   #170
denver_nieman
denver_nieman is an unknown quantity at this point
Hopefully I see some more post on this soon, will definitely be following
denver_nieman is offline   Reply With Quote
Old 12-05-2018, 08:51 AM   #171
tricky_ab
tricky_ab's Avatar
I'm all in for updates my man! I remember this build from the jump. Sorry to hear about the split, but I'm glad to hear that you're back and keeping it moving.
Instagram
Old 12-05-2018, 09:41 AM   #172
EFITTZY
EFITTZY's Avatar
Ditto, would like more updates and see this thing rip
(づ。◕‿‿◕。)づ T E A M B L O O M
Old 02-07-2019, 05:00 AM   #173
rbs14kouki
rbs14kouki's Avatar
I Parted out my sr20vet to built a 2.2 bottom end and i had a spaire head laying around that i wanted to built with kelford stuff and aftermarket shimless valves (after a saw JP r&d on the supertech vs Kelford springs) ... i couldnt convince my self to take appart a perfectly built bottom end to sleeve it and change my head completly after all those hours in it .... it sold it self for my asking price localy in 2weeks
Now building the spaire block to 2.2 and we should be good to go .
Ordered all my electronic for the car too ! Biggess financial error hahahaha but ffff-it im pump about whats coming
Motec:
M130 (gpr package with stage 2 loging)
C127 dash
Tc8 egt box
And my all ready purshace pdm15
2019 here i come
AV FABRICATION
Old 02-14-2019, 04:03 PM   #174
PoorMans180SX
PoorMans180SX's Avatar
Motec:
C127 dash
Tc8 egt box
2019 here i come
Dang dude! This thing is going to be mental.
Old 02-19-2019, 02:31 PM   #175
TheRealSy90
So what was the comparison between Supertech/Kelford and the consensus afterword?
