EVERYTHING LOCATED IN IRVINE CA
s15 long block and short block $675 complete long block has blown bottom end therefore comes with good short block with crank and end caps will include intake manifold and oil pan e11v2 haltech unit $900 gt2871r LIKE NEW no shaft play not even broken in $750 [ s13 heater box /control unit $40 s13 sohc hvac $20 s13 non sunroof fb headliner $30 s14 non sunroof headliner fairly clean $35 s13 sr20det coolant inlet $20 manual ecu $80 s14 sr20det WC ecu $120 s14 a pillars $20 s13 a pillars $20 s13 sohc auto ecu $20 s13 pop up bulbs $7 pair s13 sohc power steering reservoir $30 s14 sr20det power steering pump $50 [ s14 stock rucas $20 s13 stock rucas ,traction , toe ,tension $40 s14 stock shocks struts $40 370z sport package exhaust $150 S13 SHIFTER BEZEL all tabs in tact $25 S13 front hub BEARINGS $30 s13 sohc maf $30 doHc high pressure line brand new in bag $60 S15 SR THROTTLE BODY $40 s13 silvia lsd 5 bolt diff $90 s13 sr20det intake tube $30 TRIED TO UPLOAD IMAGES BUT UPLOADED HUGE ON THE FORUM using a mobile version of photo bucket any pointers will be appreciated heres a link to all the images http://s300.photobucket.com/user/chr...ntact/library/ (949)456 435one Last edited by project_2fizzle; 07-03-2015 at 05:12 PM.. |
http://i300.photobucket.com/albums/n...e.jpg~original
And the bearing might be a generic I'll check the engravings for you |
| s13 180sx 240sx hb, s14 240sx, sr20det |
