1989 240sx Coupe
Please text (323)807-5887 Danny
$1100 Car is registered till July 2012 Located around Los Angeles Up for sale is a 1989 240sx coupe. Practically stock aside from exhaust tip, intake, and stereo. Car is clean title with title in hand. Single cam ka24 engine. Power windows. Uncraked HUD dash. Car has some issues. I have no time or funds to work on it. Automatic trans. Reason for selling is either the car has a really bad vaccuum leak or a dirty/malfunctioning idle air control valve. Car turns off when stopped. Has an exhaust leak in the manifold. I have to force the car on by stepping on gas while Im stopped shifting from drive to neutral. Idk the real problem why it does that as I have no time or tools. Car is blue in color. Has a few barely noticeable dents.Car was keyed on driver side. It does have working AC from what I last know of but makes some noise at times. HUD works ONLY when its hot outside. Cluster lights do not turn on. My guess because of previous owner messing around and cutting through the stereo wires. Exhaust leak I'm guessing is missing bolts. Intake was replaces with a cheap one due to a ripped hose on original.(I still have original). Replaced starter, thermostat, and complete tune up with spark plugs , wires etc. Car DOES run. It is NOT a shell with engine n tranny. It's a running car with hopefully small issues. For now, just message Thnx for looking.
S13
![]() Join Date: Feb 2010
are you taking trades?
www.flickr.com/jjjcirone |
![]() Join Date: Mar 2008
trade for a Corolla?
#/f/cars-sale/410961...lla-coupe.html |
what bout a two door thats a 4 seats, it came in 4 door and its a perfectly daily
![]() Join Date: Oct 2005
I think if you fixed the driveability issue, you should have no problem getting what you're asking for. I seriously considered getting it too, but since I live about 2 hrs east of LA the car wouldn't make it home.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
| 240 sx, 240sx, nissan 240sx, s13, silvia |
