| Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here. |
I bought a vlsd from jspec.com and was wondering how i can find out what the gear ratio is, i dont want to try and count the teeth. Some of the numbers on the differential are
A5-9500330b and right under that is 19768. Its looks as though those were printed on there some how. these are casted into the housing: 68311 40F00 This looks as if it was stamped on there: 331B A5 any help would be much appreciated. philip
1993 Nissan 240sx -KAAZ 2-way -crystal clear H4 upgraded lights -sportline springs-tokico blue struts -(1)JL audio 12w3 in bandpass box-Rockford 500x-Infinity 4x6 -clarion Rdx765Dz head unit |
![]() Join Date: Feb 2002
Is it an aftermarket vlsd or is it a OEM part? The OEM part is ~4.09 ratio. Fairly high if you analyze it. If its aftermarket I would try to contact the company about it.
I belive it is an oem part, but it is from japan so i think it may have come off of a turbo s13, which i belive have lower gear ratios.
Well I really cant answer your question properly if you already know it. I know the transmission gear ratios didn't change, so why would they change the rear end ratios, I don't know.
![]() Join Date: May 2002
It's either 4.083:1 (KA24DE, SR20DE, SR20DET manual) or 3.916:1 (SR20DET automatic), most likely. There's a smaller chance it's a 4.363:1 unit from a CA18DET.
If you don't mind opening up the diff, you don't have to count the teeth... IIRC there should be a set of numbers stamped on the ring gear itself. 49/12 = 4.083:1 47/12 = 3.916:1 48/11 = 4.363:1 |
thank you for the information, that was exactly what i was looking for, it is 4.083 gear ratio.
so the higher gear ratio is the more desireable one?
'01 Nissan Sentra SE (sr20de) for sale '91 Nissan 240sx fastback (ka24de) being built .my website. |
#8 | |
![]() Join Date: Sep 2002
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (exitsanity @ Sep. 18 2002,5:50)</td></tr><tr><td id="QUOTE">so the higher gear ratio is the more desireable one?</td></tr></table><span id='postcolor'>
The higher the number, the shorter the gear, the sooner you will have to shift... I know someone with the 4.36 and he has virtually NO use for 1st gear before he redlines and has to shift. This being said, you will get worse gas mileage the shorter that gear is.
I hate you too...
![]() Join Date: Jul 2001
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (guidot @ Sep. 04 2002,02:34)</td></tr><tr><td id="QUOTE">Well I really cant answer your question properly if you already know it. I know the transmission gear ratios didn't change, so why would they change the rear end ratios, I don't know.</td></tr></table><span id='postcolor'>
Guidot, SR20DET motors in Japan will have a lower final drive ratio, as was explained in the 2 posts above mine, because you can stay in that gear longer. Normally, that's not good, but when you are boosting, you would like to stay in the spool-up area for as long as humanly possible. That's why. Same with 300zx NA vs. TT. The NA has our gear ratio, while the TT has 3.8something. -Jeff
Whatup? |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">It's either 4.083:1 (KA24DE, SR20DE, SR20DET manual) or 3.916:1 (SR20DET automatic), most likely. There's a smaller chance it's a 4.363:1 unit from a CA18DET.
If you don't mind opening up the diff, you don't have to count the teeth... IIRC there should be a set of numbers stamped on the ring gear itself. 49/12 = 4.083:1 47/12 = 3.916:1 48/11 = 4.363:1 </td></tr></table><span id='postcolor'> ok this correct to a point. The SR powered Turbo cars i.e. S14 and S15 came with 3.70:1 gears . I also am pretty sure it was the same with the S13 SR20DET cars . The 300zx TT also came with 3.70:1 gears . as far as the CA18det ratio's are concerned you are correct
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! #/f/sale-items/51531...ns-mounts.html #/f/tech-talk/317539...e-mouts-6.html |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (drift freaq @ Oct. 02 2002,10:38)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">It's either 4.083:1 (KA24DE, SR20DE, SR20DET manual) or 3.916:1 (SR20DET automatic), most likely. There's a smaller chance it's a 4.363:1 unit from a CA18DET.
If you don't mind opening up the diff, you don't have to count the teeth... IIRC there should be a set of numbers stamped on the ring gear itself. 49/12 = 4.083:1 47/12 = 3.916:1 48/11 = 4.363:1 </td></tr></table><span id='postcolor'> ok this correct to a point. The SR powered Turbo cars i.e. S14 and S15 came with 3.70:1 gears . I also am pretty sure it was the same with the S13 SR20DET cars . The 300zx TT also came with 3.70:1 gears . as far as the CA18det ratio's are concerned you are correct</td></tr></table><span id='postcolor'> according to Sam from jspec.com the s14 silvia LSD differential had the 3.92:1 gear ratio. He indicated to something on the casing of the diff itself referring to that. |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">according to Sam from jspec.com the s14 silvia LSD differential had the 3.92:1 gear ratio. He indicated to something on the casing of the diff itself referring to that.
</td></tr></table><span id='postcolor'> well it may have come in some of the cars but the info I had came straight from a ziliva member who lives in UK because I wanted to know and asked and he answered right out of his FSM.
