1992 Nissan 180sx 1JZ/R154
Hey everybody, new to the forum. Happy to finally be apart of the S-CHASSIS group
little bit about myself.. I am 21 from Alberta Canada. Present vehicles.. 92 Nissan 180sx and 2007 GMC Sierra 2500 Duramax Past vehicles.. 95 silverado k1500, 2001 gm 4.8L vortec, 2002 chev 6.0L vortec but my last pride and joy was a 2000 Acura Integra LS b18b Built with cp pistons eagle rods, brian crower cams, titanium valve springs and retainers, sleeved port/polished, Edlebrock throttle body endyne kit, t3/to4e turbo kit rc 750 injectors... much more.. car was putting down around 250 to the wheels running a safe tune @5psi and rev limiter. I sold it just shy of a full tune as I wanted to go sideways instead!! thus leading to my purchasing of a 1992 Nissan 180sx Kouki. Current possessions. Chaser; 1jz gte-vvti w/ 110,000km R154 89 supra turbo ~144,000km Bellhousing 1jz-r154 Motor/Transmission mounts Spare hatch w/carbon fiber wing Sikky sway bar Roll cage Want List: 1jz flywheel (driftmotion?11.5lbs) 7m gte clutch+pp (ACT HD 450hp .. used $400 1300km driveshaft (zerolift?) Extended shifter Custom throttle cable Wiring harness (wiring specialties?) Brake lines and BMC Battery relocation Coilovers rims(SSR vienna kreis 18s.. ~ front x10.5 rear x12) soo thats where I've come with the research I have done and etc. I have priced out most of this stuff. I also work at a welding shop so I am capable of doing some of the fabrication etc... currently off work though I exploded my foot dirtbiking recently.. so just researching, shopping and ordering so I can get to work on this bad boy. I will be taking my time, I would like to have the car mobile by fall then dissemble and repaint and upgrades..then tuned and good to go by next spring! anybody with experience doing this swap your input is greatly appreciated!! things too watch out for, easier>difficult way of going about something. anything! I will also be looking for lots of advice throughout my build. ![]() |
