Using Altima rotor with Q45 caliper
I did some search on this subject and 98 Altima and Q45 seem to be identical brake rotor except that Q45 has 28mm vs. Altima's 22mm.
That is 3 mm difference on each side of the rotor and I am wondering if this would be safe. Does anyone know how much caliper pistons extend? Can they reach rotor without pads in? Give me your opinions. Thanks. |
Eh, search harder next time, because I found this in 5 seconds.
Be sure to read all the way through, because you can't use the altima rotors according to the last page... Here ya go! #/f/showthread.p...ight=s13+rotor |
That's the first thing I saw too but they have not tested it.
They are saying it doesn't work because its thinner. I've read about people that actually tried it so I am confused. I'm just worried if caliper piston would not reach the rotor when the pad is worn because rotor is thinner. |
well... it's not hard to redrill q45 rotors to 4 lug. You can do it yourself with a 5lug rotor (to plot the dots) and a nice drill press.
Did mine in 20 minutes but ended up selling them. |
