Old 03-31-2010, 02:33 PM   #1
edub30
edub30 is an unknown quantity at this point
ABS and Viscous Questions...
Ok.. So I have a Zenki that has ABS and a Viscous LSD. I will be using the car strictly for drifting and would like to eliminate the ABS. Will it be all right to just remove the fuse for the ABS or will I encounter any issues? I also noticed that 5 lug hubs for ABS are harder to come by and was wondering if I can just swap in non ABS front 5 lug hubs? Or should I change to a non ABS spindle and 5 lug? Also noticed that used aftermarket 2 way diffs are harder to come by and more expensive new for viscous pumpkins than for the ones for the regular open end diffs. I noticed the viscous with the ABS is slightly longer. Would I be able to swap out my viscous for a regular open end diff? Would I need a different drive shaft? If I knew I would have so many issues, I would have got a base model S14. I would like to completely remove the ABS but don't want to mess with all the hard lines and BMC.. Any help will be appreciated.
edub30 is offline   Reply With Quote
Old 03-31-2010, 10:04 PM   #2
ADiamond240sx
ADiamond240sx's Avatar
ADiamond240sx is an unknown quantity at this point
I just pull the two ABS fuses under the hood when I go out and expect to get the car sideways. Also, you should be able to just swap out the internals of the differential and be ok. But I would confirm that with someone else that has done it already.
Rebuilding it one bolt at a time. Got any spare bolts?
ADiamond240sx is offline   Reply With Quote
Old 04-01-2010, 03:25 AM   #3
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
u might need the rear back plate for the diff casing but im not so sure on the s14 i know u need it for the viscious in the s13
Schassis707 is offline   Reply With Quote
