#31 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
You know I thought the same thing, but looking forever in the tubs thread, most of them do that. It won't rub though, won't even come close to rubbing lol.
#32 |
Ok, running good. Getting some miles on her to break her in. Running 14psi(spring) right now and the car feels good. I like the turbo alot, boost hits hard. Should be getting to the dyno to see some numbers next week.
#36 |
Moved to a new home, first house so my wife and I are really excited.
New home: ![]() Have a leak at the timing cover, so the motor had to come back out. ![]() ![]() ![]() ![]() ![]() Third Cosworth gasket in a year. ![]() |
#37 |
Just a little update, car was going to paint soon but I lost the Origin bumper on the f-ing freeway aha. Pretty much disintegrated the lower lip.
I'm trying to get to the dyno this week. Just some pics after the alignment. Coils not settled yet. Trying some new things for the first event coming up. -7 front camber 3/32" toe out front 8.6 caster front control arms are extended about 1" -1.2 rear camber 1/16" toe in rear stock traction length |
#41 |
Nice build! I didnt know they were bringing drifting back to PIR
#44 | ||
I dunno, is it different? I think it's an SR shroud, ka fan. Quote:
Thanks! Thanks! Hell yea, I can't wait for paint! Thanks, the house is soooo awesome. |
#45 |
![]() Join Date: Jun 2003
Trader Rating: (129)
what the shit??? explain please.
#46 |
Wut? If you are to referring to 3 cosworths, I didn't want to re-use the headgasket. All that work and to have it possibly fail by not replacing it? The hell with that.
I originally blew a cometic on the stock sr, replaced with 1st Cosworth. Blew motor, built it with a new Cosworth(2nd). Leak at the timing cover, had to pull head off replaced with a new one(3rd). |
#47 |
oh gotcha, i was gonna say, cosworth quality is top notch, if you were blowing em, i was gonna suggest having your head and block decked.
#48 |
Oh, lol ok. I didn't really get your question. Yea, Just replaced them from taking the head off. If I was blowing Through Cosworths from running it, I would have bigger problems aha.
#51 |
So Took it to the dyno a couple times now, first time the car ran dangerously lean. Fixed some shotty injector wiring and headed back.
Best number we got outta it was 344hp/311tq with the clutch slipping up top at 18psi or so, seems the clutch wasn't adjusted correctly causing the tob to rest on the pressure plate. Adjusted it, back to the dyno at some point for some numbers ahaha. DriftCrown event#2 is Saturday at PIR, first event of the season with the new motor and set-up for me. |
#52 |
Took it drifting at DriftCrown on Saturday at PIR.
![]() Then this happend: The oil block threads broke off shooting most of the oil out. I caught in time and didn't do any damage, but damn, that was close! Good friends with tow straps Hooray for AAA Proceeded to fix it earlier this week: ...and all is well again. Next drift on the 12th at PARC. |
