sr20 high idle
i have an s13 red top iin my s14 it seems like it runs like its supposed to when its cold just all the time when i start it up it will rev to about 2k and increase to 2500 if i shut it of and start it again it idles at 2k again i would like it to idle at least around 1000 also when i rev it it seems to come down pretty slowly any ideas what it could be?
![]() Join Date: Dec 2004
Trader Rating: (58)
Check for vacuum leaks, and then also check to to make sure you IACV is adjusted properly, and your TPS is showing the correct 'closed' value.
