![]() Join Date: Feb 2002
Enjuku Racing - ISR Performance HGC Long Tube Headers - VQ35DE/HR 350Z / G35
ISR Performance HGC Long Tube Headers - VQ35DE/HR 350Z / G35 ![]() ISR Performance HGC Long Tube Headers - VQ35DE/HR - Nissan 350Z Z33 / Infiniti G35 The ISR Performance Long Tube headers for VQ35DE/HR are designed to replace your factory header and catalytic converter. These long tube headers are constructed with 304 brushed stainless steel and heavy duty flanges. Designed with a stepped primary, these headers are built to retain as much low and mid range torque as possible while allowing for good top end horsepower gains as well. The innovative High Ground Clearance, "HGC" design places the collector in a position to maximize ground clearance without sacrificing performance. Each header features 2 o2 bungs placed downstream of the collector so that you can utilize your factory upstream and downstream o2 sensors. The downstream o2 sensor bung utilizes a flow restrictor to help avoid CELs. What’s in the Box: 2x Stainless Steel Long Tube Headers 2x 2 bolt exhaust gaskets 2x Head to manifold gaskets 4x o2 sensor bung plugs 4x Exhaust Nuts 4x Exhaust Bolts ** All ISR Performance Products are Designed for Off Road Use Only ** In Stock and Ready to Ship! 529.95
