Sr20det idle surge
My idle is fluctuating rapidly from about 1800 up to 2400 rpm
Sprayed carb cleaner at every vacuum connection Switched iac's Switched maf's No idea what could be the cause for this! Need some input. I have the greddy intake manifold if that's of any help EDIT: problem was a leaking IACV gasket Last edited by corkscrew; 08-05-2016 at 09:17 AM.. |
