Old 03-16-2008, 12:16 PM   #1
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Simple question.
Broke my EGR tube while removing stock header, so I'm going to JB weld the bung for it on the header, and just not have EGR. Do I also need to plug the tube itself that leads to the EGR, or can I leave that open?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
#/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 07-07-2008, 02:56 AM   #2
Jung2
Jung2 is an unknown quantity at this point
I'm in the same situation. My EGR pipping did not allign with my new header. I decided to cut the pipe and and used a rubber cap to block off the pipe the goes to the EGR (note: I did not remove the EGR) I'm wondering is this okay? Or should I remove the EGR and use a block of plate?
Jung2 is offline   Reply With Quote
Old 07-07-2008, 02:58 AM   #3
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
You have to block the line off aswell it ports to the intake manifold.
You should just take the time. to eliminate your entire EGR vacuum lines.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 07-07-2008, 03:25 AM   #4
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
if u have a DOHC i have the block off plate for the mani
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
