S13 OEM/ Isis/ Z32/ Kenwood/ Cooper
JUST UPDATED (11/13/16)
Parts are in storage so ask me for pictures if I haven't provided them. Prices do NOT include shipping. $300 - Rb20det ECU tuned by RS Enthalpy. Includes 2 or 3 chips with different maps on them. (Stock map, intake/exhaust/front mount blah blah more fuel map, and 550cc Z32 MAF higher flow turbo map) $100 - 25mm extended/ boxed S13 front lower control arms. Tie rod stops cut off. Moog ball joints and bushings. Need new ball joint BOOTS. Just the boots. $100 - Whiteline front sway bar. Added lock clearance. Comes with D bushings, no endlinks $40 - Rb20det purple valve covers $100 - rb20/rb25 top mount turbo manifold (not sure what brand. But it's brand new) has external wastegate pipe $100 - CX racing gt35 ceramic ball bearing turbo (looks brand new?) $40 OEM KA radiator $75 CX racing KA/RB/LS aluminum radiator $100 - OEM S14 KA fuel rail and injectors $80 - vintage nardi steering wheel. 4 spoke mint condition $100 - Kenwood DDX419 double din touchscreen with Bluetooth $20 - NEW Energy Suspension poly steering rack bushings $30 - Mishimoto Weighted shift knob $50 - OEM S13 non ABS manual driveshaft $50 - OEM S13 rear seats $20 - OEM S13 single din pocket $40 - OEM S13 power seat belt assemblies $40 - OEM S13 rear seat belt assemblies $30 - OEM S13 front crash support bar 100% straight. $50 - OEM S13 KA24de non-ABS driveshaft $50 - OEM S13 lower control arms. Could use new ball joints $20 - S13 5 lug conversion front hubs. Need bearings and studs. (Studs were cut to fit a 25mm spacer) Will trade for: Rear drop knuckles s13 Hydro handbrake set up w/ wilwood calipers Text 908 392 5414 -Steve Located in NJ - willing to ship smaller items. Last edited by steveff; 11-15-2016 at 07:55 AM.. |
![]() Join Date: Jun 2003
Trader Rating: (129)
pix of headunit?
Sent you a text.
#27 |
Driveshaft is manual non abs s13
Sold front seats Rear seats are just stock rear seats. No rips as far as I remember. They're in storage now I'll grab pics when I can. Sent from my iPhone using Tapatalk |
| brakes, isis, oem, s13, z32 |
