Old 04-24-2005, 03:26 PM   #1
Modern
Modern is an unknown quantity at this point
3k suspension
Hey guys im building a track car and i was wondering what would be the best suspension for 3k and under. and if possible dont say its personal prefference because i dont have ulimited money for testing coilovers. i would just like to know what would be best for track/downhill. thanks for your help.
and if possible i would like to keep it so i can have the coilovers rebuilt without waiting 8months to send them to japan or germeny.
Modern is offline   Reply With Quote
Old 04-24-2005, 03:45 PM   #2
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
There is no absolute "best" suspension, it's all opinion. If I had 3k to bank for coilovers I'd call Koni up and get a set of custom 3012/3011 shocks fabbed up.
atom is offline   Reply With Quote
Old 04-24-2005, 03:54 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
NemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfectionNemeGuero is close to perfection
Send a message via AIM to NemeGuero
it's personal preference... bwahaha.. no but seriously.. most coilovers are good.. some just have different 'feels' to them..
tien HAs or HEs are popular
GP sport gr6's
apexi N1 pro
Tanabe DDs or sustec pros
silk road rm8s
I'm sure any one of those will suit your needs
NemeGuero is offline   Reply With Quote
Old 04-24-2005, 04:02 PM   #4
Modern
anything in the tein ra and re zone?
Old 04-24-2005, 04:06 PM   #5
Modern
and i know there is no best but there is popular and custom koni's are about 1,500 (i talked to them) each thats more then i want to spend.
Old 04-24-2005, 04:08 PM   #6
FRpilot
FRpilot's Avatar
what about zeals! 3k would put you up there.
FRpilot is offline   Reply With Quote
Old 04-24-2005, 04:13 PM   #7
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
if you're spending 3K then get Tein N1s or look into motons and penske shocks
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 04-24-2005, 04:17 PM   #8
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
I'd say Zeal Super Function or Apexi N1 PRO. They are very comparable in performance but the Zeals will allow you to lower your car an insane amount more, like scraping the tension brackets and frame rails low. N1 PRO on the other hand can be found for cheaper than the Zeals.
Pretty sure the motons and penske cost like $5000.
Flybert is offline   Reply With Quote
Old 04-24-2005, 04:32 PM   #9
aznpoopy
aznpoopy's Avatar
aznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond reputeaznpoopy has a reputation beyond repute
Send a message via AIM to aznpoopy
instead of higher end coilovers i would opt for a semi budget setup like KTS from spl... instead of sending in your shocks for a rebuild they send you new shocks for 500 something when they blow up.
best part is you'll have almost $2k left over for all the other suspension goodies you should be putting on there as well.
aznpoopy is offline   Reply With Quote
Old 04-24-2005, 05:04 PM   #10
Modern
dont get me wrong im sure KTS would be fine for a street car that hit the track a few times a year. i would just like something with a good background and i know will work.
Old 04-24-2005, 08:53 PM   #11
R33GTS-T
R33GTS-T is an unknown quantity at this point
Zeal Function D or the Zeal Super Function......also check out Cusco Zero2Rs and even some Aragosta coilovers
Late,
Daniel
does your wife drive a wide-bodied sr-powered coupe???
R33GTS-T is offline   Reply With Quote
Old 04-24-2005, 09:49 PM   #12
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
KTS is known to be great. The spring rates are a bit high for my personal choice but the build quality is supurb. SUPURB! Get all polyurathane bushings, front/rear adjustable sway bars, some chassis bracing, that KTS maybe with some other little jibber jabber suspension bs.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 04-24-2005, 09:55 PM   #13
SimpleS14
SimpleS14's Avatar
Have you searched and read the multiple threads and feedback on KTS coilovers?
<== daily drives with KTS coilovers
Old 04-24-2005, 09:58 PM   #14
doc99
doc99's Avatar
doc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of lightdoc99 is a glorious beacon of light
I also daily drive with KTS, I say a set of KTS with a full multi-link from SPL would be one great track setup.
doc99 is offline   Reply With Quote
Old 04-24-2005, 11:08 PM   #15
Nismo180
Nismo180's Avatar
Nismo180 is a well-known jackass
Whiteline hands down. If I were going all racecar I'd get them. No one puts more research into their stuff, and everyone who gets them is more than happy. More than one 240 with their swaybars has been able to acheive over 1.0g maintained.
Nismo180 is offline   Reply With Quote
Old 04-24-2005, 11:19 PM   #16
chrispy
chrispy's Avatar
chrispy is on a distinguished road
http://www.advance-design.com/
I had a set of these on my old car. They're worth checking out.
chrispy is offline   Reply With Quote
Old 04-24-2005, 11:31 PM   #17
Toshiro
Toshiro's Avatar
Toshiro is an unknown quantity at this point
i think the best would probably JIC FLTA-2 cause of all the adjustability when paired with JIC tie arms
Toshiro is offline   Reply With Quote
Old 04-24-2005, 11:33 PM   #18
AutoRnD
AutoRnD's Avatar
AutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the rough
Send a message via AIM to AutoRnD
i suggest going w/ zeal coilovers.. there are many different options... Zeal's are the one of the best out there.. They are proven time and time again.. on people either auto crossing or road racing. just putting zeals in their car puts them ahead of the pack when they were once mid pack.. these cannot be said w/ some of the other coilovers... and we are talking about at a pro level... also zeals can be rebuilt and custom valved in the us
www.AutoRnD.com
Nardi, Enkei, Stance, AME Master Distributors for USA
Check Out Our Facebook!
AutoRnD is offline   Reply With Quote
Old 04-25-2005, 06:27 AM   #19
98sr20ve
98sr20ve is an unknown quantity at this point
Advanced design if it is a true track car. If it is a multi-purpose car then you have a ton of choices but I would go with zeal due to their reputation. Advanced Design are rebuildable Monotube struts. Digressive valving. Proven track performer. But it is a track setup not meant to get 15K in driving a year.
98sr20ve is offline   Reply With Quote
Old 04-25-2005, 10:18 AM   #20
wootwoot
Been reading SportCompactCar eh?
Old 04-25-2005, 10:20 AM   #21
AutoRnD
AutoRnD's Avatar
jic is the worst suspension ever! i would never even get close to it with a 10 foot pole... they are evil... crappy service.. crappy us specs...
www.AutoRnD.com
Old 04-25-2005, 01:11 PM   #22
-=MCR=-
-=MCR=-'s Avatar
-=MCR=- is an unknown quantity at this point
top secret aragosta coilover setup XD
-=MCR=- is offline   Reply With Quote
Old 04-25-2005, 01:38 PM   #23
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
adding:
HKS Hipermax PRO
Ohlins (rare to get here, probably $$ to get rebuilt)
but for what you're looking for (rebuilds here, customer service) I would get the Zeal Function V6
there are the Zeal Function X and XR, Zeal's high end,
although i'm not sure if those models are rebuildable stateside
18+ to come//21+ to swallow
anthony240 is offline   Reply With Quote
Old 04-25-2005, 01:55 PM   #24
AutoRnD
AutoRnD's Avatar
all zeal coilovers are rebuildable as well as valveable in the us...
www.AutoRnD.com
Old 04-25-2005, 07:25 PM   #25
Modern
im not sure what you are talking about but i never said that kts isnt good for daily driving. i said that its good for daily driving and going to the tracks once in a while. this is a straight track car.
Old 04-25-2005, 07:28 PM   #26
Modern
and ill check out the zeals thanks guys. if you think of any more please tell me
Old 04-25-2005, 07:45 PM   #27
Modern
is there any word on Toda racing fightex?
and this question is not mine but my friends.
what would be a good high end drift coilover
zeal super function
tein HE
kts umm kts?
or any you can add
Old 04-25-2005, 08:11 PM   #28
d4vech3n
d4vech3n is an unknown quantity at this point
Get higher end coil overs (about $2k) and spend the other grand on pillowball arms and bushings.
d4vech3n is offline   Reply With Quote
Old 04-25-2005, 08:25 PM   #29
l33tmonkeyman
l33tmonkeyman is an unknown quantity at this point
Send a message via AIM to l33tmonkeyman
if you wanna put all into coils then u def should go kei office, zeal, or spl aragosta coils. but otherwise i would recommend the kts coils. they are only 1200 and are able to get new shocks for 550 and thats for all 4. the silkroad rm8s have to be shipped out to be rebuilt i believe so more downtime is there. But with the kts u ccan get new sways, tons of adjustable multi-link rods, rims, tires. much better for custom alignments also
l33tmonkeyman is offline   Reply With Quote
Old 04-25-2005, 11:54 PM   #30
thx247
thx247 is an unknown quantity at this point
Something from the US or that has local US support. Probably GC's or Koni's....
Wouldn't spend money on many arms...TC rods, subframe bushings and a LSD of some type. Spend the rest on tires.
If you need some sorta adjustability in the suspension I guess you could go with arms, but you won't see the same returns you will see getting the basics.
Peep the things I did to my car, was not worth the total costs for the return it gave me. Fun car and all, just you could spend money on other things to get you really close to the same point.
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
