#216 |
![]() Join Date: Jun 2007
ehhh not really.. i got the 8c^2 so itll have a similar spool time as the 2871r...
got it, a lovefab mani, all I/C piping, new Sard racing bov, FM, and a dp for 2k... the mani alone was 1800 after he paid for it to be ceramic coated.. itll be on as soon as i get a 44mm WG |
#217 |
![]() Join Date: Jun 2006
I'll post up my dyno sheet after next tuesday when mine gets tuned.
Redtop GT2871R .64 Tomei 256/256 poncams 740cc Tomei injectors z32 maf Walbro 255lph HKS fmic Greddy elbow Blitz downpipe Megan test pipe Apexi GT Spec exhaust Power FC Hoping for 350whp Last edited by 1cleanS13; 05-10-2008 at 02:00 PM.. |
#221 |
![]() Join Date: Jan 2008
drove my 240 for the first time since the tear down for the build last august.
it sucked cause it was only on a dirt road but my gt287r .64 was spooling so fast. i had to be careful cause the road was so rough and if i barely opened the throttle it would want to take off. On pavement it would have beena different story. |
#223 |
![]() Join Date: Dec 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
im in the porcess of building my my fisrt sr
so far New 2871R .63 megen manifold (came w/ the motor) godspeed fmic (also^) a leaky ass bov lol (will be replaced) New CP Pistons New Eagle Rods New Cometic gasket New Acl Bearings Set New Supertech valves,retainers,springs and a full gaskets set i want to make 300 or a bit over if i can. im planing on up grading the fule system but i dont know what route to go.. and how to manage it but before i want to break it in am i safe with my 370cc on my 2871r?
#226 |
I agree with both of these guys. I have babied my car the last 5 months since adding the gt2871r because I was running stock injectors, maf and ecu the whole time and didn't want to take any chances of leaning out and popping my motor. I haven't given my car more than half throttle in 5 months, after tueday when I get my tune I can finally beat on it. Needless to say I can't fucking wait! lol. |
#228 |
I expected more from my set up, but the guy that tuned it said he wanted to do a "conservative" tune on 91 octane pump gas. I was hoping to run 16-20 psi but the tuner said no way unless we did a race gas tune.
So at 1 bar on a dynapack dyno: 315whp 289wtq Mods: Redtop GT2871R .64 Tomei 256/256 poncams Walbro 255lph 740cc Tomei's Z32 maf HKS fmic Greddy elbow Test pipe Apexi GT Spec exhaust Blitz downpipe stock intake and exhaust manifolds Power FC Greddy profec B spec II The thin lines is my baseline when I had my stock t25 at 14psi. What do you guys think? He tuned my AFR to 11.5 at WOT, I'm kinda new to this and this is my first time getting it tuned...Would it make more power at around 12.0 AFR? ![]() Last edited by 1cleanS13; 05-15-2008 at 12:56 AM.. |
#229 |
![]() Join Date: Nov 2007
Hey i've got pretty much the same setup as you.^
Hope fully i'm going to get my car tuned within the next few weeks. SR REDTOP gt2871 .64 hks adjustable actuator deatsch 740cc megan elbow ssac test pipe Apexi N1 3in exh with N1 muffler hks step 1 256/256 10.5mm lift Xs-Engineering FMIC Apexi AVCR Power FC L-Jet I'm hoping to run about 17 lbs of boost and hit 350. might need more lift on my cams and a slight bit more duration. anybody want to swap me BC cams? PM me. |
#230 |
I was hoping for around 350 too around 17-18psi but my tuner wanted to be more conservative with our crappy 91 octane.
My powerband is pretty awesome so for now I'm still happy with what mine did at 1 bar. |
#232 |
![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Has anyone had a turbo that constantly gained boost?
On the dyno at 1/4 throttle boost showed 3-4 psi until 3800-4k rpm then it spiked to 18-19 and climbing. It did the same thing with the wastegate flapper held open. I don't know much about tuning but the tuner said with the flap held open it should not make any boost or much at all. I drove the car before the tune and it held 14 psi on my brand new stri gauge. I told the tuner that and he said my timing was 25 deg off and that was all it would make. I would think with timing that far off the car would hardly run at all. My turbo was bought brand new from precision. |
#234 | ||
![]() Join Date: Oct 2003
v-mount ftmfw. |
#235 |
i second that.... but plan to do the extrude and swain sometime soon. Also think i may change to E85 setup and get a complete re-tune.... Should make a bit more power and cheaper at the pump....
#236 |
yeah I pulled my turbo and manifold off. I noticed where the manifold goes to the engine it was black for about a 2 inches then changed to brown and where the turbo bolts to the manifold it was also brown.
Is there any reason for that? |
#237 |
Is it true that dynapacks read about 10% lower than dynojets? I saw a few comparison vids online showing back to back runs on the same car and conditions and the dynapack consistently read 8-10% lower every time no matter what car.
I was kinda wondering why my numbers seemed a little low at 1 bar making only 315whp and 289wtq.... Also, is the general rule of thumb that 1 psi = roughly 20whp? If so, at 18psi I should be around 370 which is what I expected but my tuner would only do a "conservative" tune on 91 octane pump gas. I thought the gt2871r .64 was most efficient between 18-21psi.... |
#239 |
Cool, thanks for the info. Do most people run race gas or pump on 18-21psi? Most people do not state that in their posts when I am looking at all these dyno #s. I am in Arizona and it gets to 110 degrees here in the summer and all we have is 91 octane readily available so I dunno if it is that smart to run that high psi anyways in my conditions?
#240 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Nice numbers mang. Nice to see another smart 240 owner not wasting time with the tubular stuff
![]() Your car would be an EXCELLENT candidate to see the differences in gain/loss with a Greddy Plenum. Quote:
