![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
0 oil pressure at idle
So my oil pressure at idle drops to 0 once the engines warmed up.
im thinking its the sending unit for my gauge though cause the engine seems very happy and I beat the shit out of it. I cant hear any knocking or any noises youd hear with no oil pressure. you can let it idle for an hour no problems just wondering if anyone else has experience a sending unit failure like that before and if they are common
The Game you lose haha |
![]() Join Date: Apr 2014
I had the same thing happen on another car. Once warmed up if I came to a stop the pressure would drop to 0, replaced the oil pressure switch/sending unit and the problem went away.
sounds like sending unit failure for oil pressure gauges is fairly common.
I also noticed the gauge needle seemed to kind of stick a little shortly before it failed like I said I didn't hear anything out of the ordinary so I can say with confidence its an oil sending unit failure
