![]() Join Date: May 2015
Sr20det hold measurements
s13 Sr20det build measurements
Hey guys so I'm almost done! Block is being machined and once I pick it up it's going to be assembled. Now this is where I am stuck. I ordered standard ACL main and rod bearings. I wanna get the measurements and clearances right so I don't spin one. What are my cleanrsnces for the rods and mains? I'm going to get a micrometer and such today. Also I'm reshimming the head as I'm not taking any chances at all!! Sr20det red top Oem de 9.5:1 pistons brand new Oem connecting rods Oem head studs brand new Cosmetic ml3 headgasket Brian crower stainless steel valves Super tech valve seals Isr performance gasket kit (Beginner rebuild trying run 300whp safe) |
You already ordered the bearings...
You'll need a bore gauge and micrometers, (not cheap digital calipers) The clearances are in the FSM
MRP Manufacturing |
