Old 12-02-2007, 03:11 PM   #1
Farkel
Farkel's Avatar
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Farkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura aboutFarkel has a spectacular aura about
Send a message via AIM to Farkel
How to Adjust Coilovers without Spanner Wrench?
I'm not quite sure how I'm going to adjust the ride height of my springs once the coilovers are on the car
I didn't get a spanner wrench with them and I can't seem to source one out... Any makeshift method I could use with normal tools?
★ ★ GRANDMIGHTY.COM ★ ★
Farkel is offline   Reply With Quote
Old 12-02-2007, 03:15 PM   #2
Sidewayzzz
Sidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura about
Send a message via AIM to Sidewayzzz
flathead screw driver, a hammer, and a towel.
Sidewayzzz is offline   Reply With Quote
Old 12-02-2007, 03:21 PM   #3
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
ive seen larger wrenches being used...but spanner wrenches are pretty easy to find. what brand of coilover is being used? alot of times you can get ones directly from the manufacturer. also, i know they make generic ones through summitracing.com companies like moroso make them.
to adjust them, i usually get the car off the ground (i usually use a lift.) and adjust...until its where i want it.
burnsauto is offline   Reply With Quote
Old 12-02-2007, 03:25 PM   #4
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
big flat screw driver and a hammer
ROIDMONKEY is offline   Reply With Quote
Old 12-02-2007, 10:55 PM   #5
serturbo
serturbo is an unknown quantity at this point
Slip joint pliers could also work.
serturbo is offline   Reply With Quote
Old 12-02-2007, 10:56 PM   #6
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
You should def get the spanner wrenches....ones salt and sand and stuff get up in there, it can be hard to crack them loose sometimes
but ya screwdriver works for now i guess
Daily driven
jspaeth is offline   Reply With Quote
Old 12-03-2007, 08:55 AM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Monkey wrench works too...
CLICK HERE!!!
Old 12-03-2007, 09:04 AM   #8
SHIFT_Slide
SHIFT_Slide's Avatar
SHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really nice
Send a message via AIM to SHIFT_Slide Send a message via MSN to SHIFT_Slide
Chain strap wrench works the best IMO.
SHIFT_Slide is offline   Reply With Quote
Old 12-03-2007, 09:57 AM   #9
KA24DESOneThree
You honestly can't seem to source one out? Are you serious?
Search the words "coilover wrench" on Google. Nine out of the first ten responses are places which sell coilover wrenches.
Old 12-03-2007, 11:32 AM   #10
Slidin240Wayz
Slidin240Wayz's Avatar
Slidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfectionSlidin240Wayz is close to perfection
Where do I search?
Yes...coilover wrenched can be had easily.
Slidin240Wayz is offline   Reply With Quote
Old 12-03-2007, 11:50 AM   #11
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
i used a oilfilter tool
dvdevo is offline   Reply With Quote
Old 12-03-2007, 12:11 PM   #12
CAPTAINNEO
CAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond repute
Send a message via AIM to CAPTAINNEO
for some reason never thought/used either of these...great ideas.
but yea, you can get them anywhere...like everyone else said, hit up the manufacturer. i know the guys at tein sell so many they sell them at shows/events..
CAPTAINNEO is offline   Reply With Quote
Old 12-03-2007, 12:23 PM   #13
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
wrap it with a towel, and use chain links
((sr)) kelly is offline   Reply With Quote
Old 12-03-2007, 12:46 PM   #14
trsilvias13
trsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to behold
Goto a motorcycle shop, they usually carry spanner wrenches in stock. That how I use to adjust my coilover (apexi)
trsilvias13 is offline   Reply With Quote
Old 12-03-2007, 04:12 PM   #15
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
post up in the local forum see if somebody has a set, you're bound to find somebody with another set of coiliovers like yours that will be willing to loan it to you. You arent one of... i doubt you're that special.
parking lot pimpin...
Seller Feedback here:
#/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
