Replacing a KA24DE
Is there a thread on here that explains how to properly remove and install a KA? Ive searched and havent come up with anything on what im looking for. Is there like a process you have to do or is it just so easy you dont need instructions. Cause i really dont want to screw it up while swapping motors (ie: bend hard lines, break lines, cut wires). Is there any certain way to do this or is it just unplug/hook everything holding it in and pull it? Any help would be appreciated. Thanks
Gus
2003.5 Laser Mica Blue Mazdaspeed Protege #2707/2750 |
![]() Join Date: Dec 2002
It's like removing any other engine. Unbolt it, unplug every thing, disconnect hoses, pull.
It's not rocket science.
![]() Join Date: Mar 2003
FSM will tell you if you really need to know, but in that case, are you sure you should be swapping it?
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels. |
