Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 04-26-2012, 06:58 PM   #1
adicarlo
adicarlo is an unknown quantity at this point
240sx to 240z parts swap
So I just picked up a 240sx with a SR20 that I'm planning in the future to use as a donor car for a 240z.
My goal is to tune the motor in the 240sx and suspension components and bring over to the Z one I find a non running one and get it thru paint and body.
Now when swapping the motor people do two things:
1. get a custom fabbed crossmember (McKinney Motorsports), trans mount, and drive shaft.
2. Buy custom engine mounts and use the stock cross member.
Now my goal is the bring the entire front suspension from the SX (knuckles, hubs, LCA, tension bracket, and if possible power steering rack) to the Z.
Does anyone know if the McKinney Motorsports Crossmember includes the mount points for the LCA and will the 240sx LCA fit within these mounts?
Or If the 240sx LCA's with fit within the Z factory cross member?
adicarlo is offline   Reply With Quote
Old 04-26-2012, 07:57 PM   #2
ROGUE_RB
ROGUE_RB is an unknown quantity at this point
#/f/z-chassis/414246-71-s30.html
read this it will tell u what u wanna know..
ROGUE_RB is offline   Reply With Quote
