Old 12-26-2008, 12:36 PM   #1
jkettell
jkettell is an unknown quantity at this point
s13 Help!!!
i have an s13 with an sr20det.
this happened after i put my hazards on. after i turned them off the right turnsignal stays on and dosent blink just stays on when the headlights are on. when the headlights are not on the turnsignal works fine. any ides???
jkettell is offline   Reply With Quote
Old 12-26-2008, 12:40 PM   #2
xblack240x
xblack240x's Avatar
xblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the rough
Send a message via AIM to xblack240x
Check all the wiring for the turn signal. That's what I would do anyways...
xblack240x is offline   Reply With Quote
Old 12-26-2008, 07:01 PM   #3
Hawaiian240
Hawaiian240's Avatar
Hawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud of
s13
Yeah, check the wiring first. It may also be a problem with the combination switch. Check the factory service manual for the "combination switch check"...the diagram is on page EL-17.
I had a problem with my headlights working intermittantly while the switch was on. Turned out the combo switch was old, the contacts had built up a high resistance connection, heated up to the point where it had shorted in some places and thus needed to be replaced.
For Sale threads:
#/f/sale-items/33286...tons-pics.html
Review Thread:
#/f/private-sellers/...-chhheeee.html
TRADER RATING:
#/f/traderratings.html?u=66301
Hawaiian240 is offline   Reply With Quote
