Old 02-02-2015, 04:09 AM   #1
240sxDude
240sxDude is an unknown quantity at this point
S14 Tach Speedo doesn't work
ok so i been out of 240's for about 4 years now.
But Im about to pick up another 95 zenki, guy says tach and speedo doesn't work. He says it needs a lower harness.
Is this true and will it fix it. And around about how much to fix if it is the lower harness.
Thanks
240sxDude is offline   Reply With Quote
Old 02-02-2015, 02:06 PM   #2
240sxDude
Anybody have a idea? Trying to find out if i should buy this car ir not.
Thanks
Old 02-12-2015, 07:02 PM   #3
SteeleBrothersDrifting_Mike
SteeleBrothersDrifting_Mike's Avatar
SteeleBrothersDrifting_Mike is an unknown quantity at this point
Tach should work without lower harness as long as the wiring harness is not haggard and it's getting a good signal. You need a lower harness for speedometer regardless and it needs to have a good speed sensor to work
SteeleBrothersDrifting_Mike is offline   Reply With Quote
