bushings for this diff
im new to the Nissan chassis, got a subframe from an 89 240 coupe, I'm guessing this did did not come from this car because i cannot find these bushings any where. can someone tell me where i can find them or tell me what this diff came out of?
#9 | |
![]() Join Date: Nov 2011
![]() If you're looking for the whole bushings assembly, it's easier to get solid bushings like stated before SPL,Stance,PSM and others make them. they should be under S14/Z32 A solid bushing? Yes. I have S14 solid bushings on my J30 diff. S14/Z32/J30/Q45 all have interchangeable bushings.
#10 | |
My guess is it's an S14 but I need pictures of the whole diff. |
Yes. Only difference is that J30/Z32 have a sleeve on the OEM bushing whereas the S14/R32 don't. So if your diff has a sleeve it sucks to take out.
J30/Z32 sleeve looks similar to this. (This is on a subframe, used for illustration pusposes) ![]() ![]() S14/R32 bushings is just that. Pull out and replace. |
