Old 04-09-2011, 04:30 PM   #1
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
rb26 into 13 help!
yo whats up yall need some help figuring out what i need to reroute and block for single turbo set up!
okay well first i need to know if i should just block these guys off or just run them into each other (if that makes sense), their for the stock oil cooler
also want to know what i do with these guys, 2 are for boost i think and the other two are the coolant, i was wondering if i could just use these guys as a boost source, and if i just block the coolant one's!
TurboStrong is offline   Reply With Quote
Old 04-10-2011, 05:26 PM   #2
TurboStrong
anyone out there!!!
dont be scared of the spider webs!
Old 04-10-2011, 05:51 PM   #3
Sileighty_85
Sileighty_85's Avatar
just loop the two oil cooler lines
use or block off the boost lines and cap the coolant feed lines.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-10-2011, 06:17 PM   #4
TurboStrong
sweet thanks dude, last thing does it matter at all which brake booster vacuum line i use since the rb has two?
Old 04-10-2011, 06:50 PM   #5
Sileighty_85
nah doesnt matter
後輪駆動車1番
1986 SR86 - 200ish
