06-03-2011, 12:59 PM | #1 |
wire reverse light s14 with s13 transmission
I have a 97 S14 that was previously auto and owner converted it to manual.
he put in a s13 transmission but did not wire up the reverse light. anyone have any insight on how to wire it up? |
06-04-2011, 01:04 AM | #3 |
What do you mean by didnt wire it up? You talkin about the reverse sensor thats on the s13 tranny? When I bought my S13 my reverse light didnt work, I check all the wiring going to the light and didnt find anything wrong, I later dropped the tranny to change the clutch and found 3 of the 4 transmission sensors were cut, one of them was the reverse light sensor, I got a new one from the dealer, plugged it in and it started working.
Hope this helps. Here is a pic of where the sensors are located. |
06-06-2011, 09:58 AM | #4 |
was your car a s13 or s14?
mines is s14 with s13 trans. so do i just tap the negative and positive wires to the reverse light sensor under the engine bay? |
06-06-2011, 10:51 AM | #5 |
Mine is a S13, the way it works is that all 4 sensors on the transmission plug into a lower harness that runs below the engine and along the transmission, I don't know how it is setup on a S14, but I would expect a similar setup.
