Ok so here's the thing. I have had this noise that I have been trying to track down for a while now. It is hard to track down. I thought it was coming from under the valve cover at first. My friend insisted that it was one of my bearings saying it was my water pump bearing. I replaced the water pump and low and behold that was not it. It is a very high pitched noise that only occurs at lower RPM, typically 1-2K RPM. Its evident if I blip the throttle. I have been having a hard time trying to find any thread with symptoms similar to mine but can't so requesting help for the Nissan Noob. Oh and I have an S14 with an SR20DET. It is a notch top if that helps.
![]() Join Date: Dec 2007
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
im with onevia_drift on this one.
i have a similar problema, and my mechanic said that it was my clutch throwout bearing. when i start my car, it squeaks, but when i press the clutch it stops. luckily its 25dllrs for my ka ![]()
taking corners just as good as a drunken rhino..
I don't think it is the throwout bearing because it seems to come from the motor and it is not constant or at an interval. It only happens when I pass through around 2k RPM and it doesn't matter if I have the clutch pressed in or not it will make the noise. I will try to tape it but it is a very high pitched noise. After 2k RPM it is inaudible and the same for under ie. at idle.
![]() Join Date: Dec 2008
Trader Rating: (35)
![]() Feedback Score: 35 reviews
you could be low on oil..the noise may be the valves, and when you accelerate more oil is forced into the valvetrain henceending the noise
![]() -Jorge |
![]() Join Date: Apr 2010
Its a S14 Sr20det yes? Alot of them have their VCT or VVT, whatever u call it, go out. does it sound like this?
YouTube - Sr20Det VVT rattle. sorry for the horrible vid. |
Ok so I know it took a bit, I've been a bit busy, but here are pics of under the valve cover and a video of the noise. Everything looked ok under the valve cover. Nothing looking like it was oil starved or anything. Also I have been trying to find this noise and I just can't. My A/C went out for a bit so I ran without the A/C belt for a while and it still made the noise so I don't think that it's the idler pulley. You can hear how the noise only shows up while I pass through that low RPM band.
No thanks a big screwdriver works just as well and I couldn't track it down.
lol thanks I have a Greddy Type RS. I didn't think it could be related to that but it seems it was. I tightened the adjustment screw towards harder setting and it stopped the noise. At low RPM at least I only slightly hear it at like 6k but at that point the engine noise drowns it out lol. |
#17 |
The only things that pisses me of is I keep getting a Juttering sound from the BOV and it almost sounds like compressor surge which worries me. On the plus though it doesn't make that high pitched noise anymore.
