Old 10-08-2010, 11:46 AM   #1
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
Caster all off after tension rod and tie rod install.. help
I installed adjustable tension rods, and new stock inner and outer tie rods. Went to my friends alignment rack. He sets my caster around 6.5-7 degrees which is where its supposed to be. Then as im driving home i realize my tires are hitting my front bumper when i turn. The tires were were almost touching the bumper all the time sitting too far forward..
So i backed them off using the tension rods so they wouldnt hit the bumper.. but one side i had to adjust a lot more than the other. Im even on both sides, go back to the rack and my caster reads 8 degrees on one side, 9.5 on the other.... now if i move it back down the tires will be close to the bumper again.. just trying to figure out why this is happening? I cant imagine high caster can be good for drifting and i got an event next week.
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline   Reply With Quote
Old 10-11-2010, 09:28 AM   #2
Datenshi
Datenshi is an unknown quantity at this point
Bent frame?
Datenshi is offline   Reply With Quote
Old 10-11-2010, 10:13 AM   #3
Triperformance
Triperformance is an unknown quantity at this point
Agreed with bent frame but you do want a good bit of caster, allows the wheel snap back for you which makes the wheels track forward. You want less caster for road racing though.
Triperformance is offline   Reply With Quote
Old 10-11-2010, 12:06 PM   #4
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
The longer the arms the less caster you will have...the shorter the more
Totally, wrong, more caster is also desirable for track cars as well! The only time I can see you not wanting a ton of caster is in super heavy duty/weight setups, like trucks and that sort.
Old 10-13-2010, 01:06 AM   #5
rightcoastimports
im going back to the rack tomorrow to try and figure it out.. before i installed new tension rods, the caster was fine.
Old 10-13-2010, 06:03 AM   #6
PoorMans180SX
PoorMans180SX's Avatar
Yeah, lengthening the tension rods should make you have LESS caster.
Make sure the alignment machine is calibrated and make sure you compensate the wheels right.
Make your adjustable tension rod the same length as your stock rods, then go from there.
BTW, you want less caster for drifting, like 6*. Why? It keeps your wheel flatter at high steering angles, giving you more front grip in drift.
Old 10-13-2010, 09:07 AM   #7
codyace
codyace's Avatar
Trader Rating: (58)
You should see me when I play with Mustangs, it's all backwards to me then hahaha
Old 10-13-2010, 12:55 PM   #8
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Make sure you got tension control rods for the right chassis...
