Old 03-19-2007, 02:26 PM   #1
skate07
skate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-known
outer tie rod compatibility .... s13 > s14
are tie rod ends the same for both s13 and s14?
i have found answers that say yes, and searched and heard tons of the "run around"...
local shop has some s13 ones, i need some today, will they fit my s14?
so someone settle it, thanks a bunch
s13 and s14 tein tie rods use the same part number.
but moog s13 and s14 have different part numbers
skate07 is offline   Reply With Quote
Old 03-19-2007, 03:59 PM   #2
cdlong
cdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud ofcdlong has much to be proud of
Send a message via AIM to cdlong
i think they are different. tein rod ends are supposed to work with s14 inner rods.
cdlong is offline   Reply With Quote
Old 03-19-2007, 04:01 PM   #3
darius_tii
darius_tii's Avatar
darius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura about
Send a message via AIM to darius_tii
how are the moog outters compared to the tiens?
Anyone know
Thanks
Darius
http://wolfreign.wordpress.com
Darius
darius_tii is offline   Reply With Quote
Old 03-19-2007, 04:04 PM   #4
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
stock OEM inners/outers are not the same for s13/s14.
Teins inners/outers are the same for s13/s14.
Flybert is offline   Reply With Quote
Old 03-19-2007, 04:47 PM   #5
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Tein inners are some how compatible with both.
But stock like Flybert says are different.
S13 S14 and Z32 are all usable on any S-Chassis.
Old 03-19-2007, 05:10 PM   #6
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
OK... Thought this info was known.
Stock S13, S14, S14 Tie Rods (inner) are 10mm thread.
However the S14 Inners are bigger, longer, & stronger then both the S13 and S15.
Stock Tie Rod Ends (outer) are different because of the thread depth... S14 is Longer, S13 and S15 are about the same, and Z32 is shorter.
Tein Tie Rods (inner) are about 10% stronger then Stock S14, and also use a 12mm Thread so they can be used with aftermarket Ends (outer) like Kazama, SPL, etc..
* Tein Tie Rod (inner) and Tie Rod Ends (outer) can NOT be used in combination with the original equipment tie rod and tie rod ends.
URAS, Kazama, etc.. and other Aftermarket Tie Rods (inner) are sigificantly stronger then S14 Stock and Tien... and is mainly the reason for costing twice as much.
Tein is a great alternative for cheep quality replacement and you can use Aftermarket in conjunction... for this IMO Tein is your best bet... however if your bending Rods alot durring Drifting I highly suggest spending a little more on the URAS, Kazama version Rods!!
Peace
Drew
URAS
MadScientist is offline   Reply With Quote
