| South Western States Arizona, California, Hawaii, and Nevada. |
![]() Join Date: Oct 2011
![]() Feedback Score: 15 reviews
Rb25 mechanic needed!!!
Need help with my rb! Near rialto ca if anyone can come by today or during the week that would be great please if you can really help hmu and I'll Gove you details on what the problem is. (909)644-2534
MmmmmmTACOS |
#3 | |
MmmmmmTACOS |
This car is really starting to piss me off. Took a day to do the swap and it's been about 3 weeks trying to find the problem
MmmmmmTACOS |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Might be a vacuum leak on the manifold. I used a different intake manifold gasket and had to replace it due to a leak. When the engine is running spray all around the intake and ic couplers with carb cleaner or brake cleaner, if the idle jumps you've found your leak.
Just a shot in the dark but the O2 might be going
Did you tighten the manifold correctly? For intake manifolds I usually like to bolt down from center and work your way to both ends evenly. I usually make 10 passes to get each bolt tight evenly and properly, I've had intakes bind or not seal properly.
Yes I tightened from center towards out. Problem has been fixed now. One thing now is when it starts to make boost it starts lagging. Checked everything and found that my alternator is sending 14.2 bolts and the battery is only receiving about 13.5 volts then the fuel pump is only receiving 10volts so Ima rewire my power cables (found corrosion) and try that. If that doesn't work then that will most likely tell me that fuel pump is ready to give out
MmmmmmTACOS |
