Wassup fellow enthusiasts. I recently picked up another s13 with a sohc with a timing issue. After trying to time it right over and over, I came to find that the oil pump isnt put in and aligned properly with the distributor. Ive been told and read that the oil pan has to be dropped in order to loosen and turn the oil pump to align right with the dist, but im wondering, can I loosen it just enough to pull out and turn (to proper alignment) then put back in?
![]() Join Date: Apr 2007
oil pump is 4 bolts, can be dropped without dropping pan.
you can make timing the motor a 10 min job drop oil pump and pull the gear shaft out. if you take the grinder and cut the half moon off the tip above the small gear that drives the distributor. while oil pump is out pull distributor cap off then the distributor itself. set motor to TDC then adjust to 15deg BTDC put oil pump spindle and pump back in then set dizzy to cyl 1, it should slide right on with minimal effort. button everything down and fire her up
KAe-T goal 400whp with A/C - Hatch VH45 track duty - Titan VK56 tow rig |
#3 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
msglength
its not needed, directly below the half moon is a gear. so the half moon is double redundant
| 1990, ka24e oil pump, s13 |
