![]() Join Date: Mar 2013
final drive on jdm r200
i tried searching guyz!
![]() anyway, i changed my whole differential case cause i thought i had a problem with my diff, and got a JDM s13 group (case, internals and cups) from a guy. i thought it was identical to mine, though i spotted two differences. the abs sensor was a different diameter, and there was a number on the case, if i remember correctly the one was X6, the other 7. anyway i put it on the car and i'm sure the final drive is shorter. i like it. if my memory serves me well, on the dash, 100kmh was 110 on the gps, with this one 100=100 so, what final drive ratio might i have?
My Build |
![]() Join Date: Apr 2004
It's probably a 4.36 diff assuming you had a 4.08 stock.
The only way to know for sure is to open up the back cover and look at the ratio stamped into the ring gear. It'll be two numbers like 48:11. Divide them for the ratio, in this case it's 4.36.
