Helpp rb25det
hi im new here
im from dominican republic and i reacently swap my silvia S15 with a RB25det engine i went all the way with the greddy style intake plenum and the Q45 big 90mm throttle body... the problem im having its when i go full throttle on the accel ... the car have a hugee cut its almost like it turns off and if you realese the gas pedal and punch it slightly again it run again and keeps doing it and doing it (but only when i go on full on the gas pedal) im probably thinking that the problem comes from the MAFF that im using the stock RB25 MAFF anywayss please help me with this |
i solved the problem..... i changed the mass from OEM to the z32 MASS and then change the stock tps plug for the Z32 tps plug.... and noww the car its running wilddddddd.. looking forward to getting the car to the dyno and boost that bitch up and set the fuel psi to the right air fuel ratio .... ill keep you posted on the progress
