Need Help Diagnosing
I just got my ka rebuilt and i went to go get a smog check as i was pulling out of the drive way i heard a loud grind trying to reverse . I immediately shut the car off, started it a couple minutes later and no noise so i took off as i was driving i noticed a bit of a grind shifting in between gears, i pulled up to the station and the grinding began again so i pulled into a neighborhood and parked.
I'm stuck on what this problem could be, any ideas? i didn't have this problem before my engine got rebuilt and the clutch was still in decent condition.The car will go into gear while off but once i turn it on it will grind going into gear and also while i try to drive it. any help would be great. I apologize if this has been covered already but i haven't found a thread on my exact problem |
![]() Join Date: Sep 2005
Trans has fluid? Diff has fluid?
Master and slave function properly? Clutch releases from pp and fw? Try starting the car with trans in gear clutch in. Well you could need to replace the clutch. So do some slipping clutch test. Of course, something could be broken, but who would most likely find it? Sent from my LG-H631 using Tapatalk
Does it grind all the time when your in gear? Does it grind just when your just shifting? How about when the clutch is engaged or disengaged? To expect someone to try to figure out a problem, especially over the internet the more details about your issue the better, less guess work on our end and less throwing parts at the problem/wrong diagnosis. Just pay attention to what your doing when it happens.
| help needed, ka24de, transmission 5speed |
