Old 02-10-2014, 07:25 AM   #1
PW180SX
PW180SX's Avatar
Trader Rating: (32)
PW180SX is an unknown quantity at this point
Feedback Score: 32 reviews
'91 S13 weird electrical issue - any ideas?
Hey everyone,
Did a bunch of research, can't exactly pinpoint my problem. Electrical is not my strong suit...so any input would be appreciated.
Here's my problem. I've had this issue with two motors now (RB & KA), but when I start the car everything runs just fine. But other than the clock on my cluster and the aftermarket gauges, no other electronics work. Windows don't work, RPM doesn't work, CD player doesn't work, headlights/blinkers don't work (well, headlights work, but the motors don't operate). Nothing works UNTIL I rev up the motor to about 3-4K, then everything fires up and works fine.
Even with the key to the ON position, then only thing that does anything is the fuel pump. No warning lights, CD player, windows, power seat belts etc.
Any ideas as to what this could be? I figured it's a ground issue with the chassis harness or even a battery/alternator problem. I went through every ground, sanded down the contact area etc. Battery has good connection (it's low on juice, but I tried swapping it with a known good battery and still has the same issue) and the alternator has to be good cause the motor I have now (KA) came out of my friends car he daily drove up to the point of removal.
The only thing I've done to the chassis harness is fix the fender harness issue and tucked it up. Maybe something is grounding out?
I'll also point out, the battery has been relocated to the trunk. But I did this two years ago with my original KA and it worked perfectly fine.
Any ideas would be appreciated, thanks!
Build Thread: #/f/showthread.php?t=580492
IG: roadpirate
PW180SX is offline   Reply With Quote
Old 02-10-2014, 07:38 AM   #2
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
So nothin works but engine related stuff and the gauges you put in with the engine running? Do you have power a the fuse box ( each fuse) Check that first. that's a pretty wild problem idfk start there it may come down to looking over the fender harness tuck.
foreverdeath is offline   Reply With Quote
Old 02-10-2014, 07:44 AM   #3
PW180SX
PW180SX's Avatar
Trader Rating: (32)
Yeah exactly. It's pretty crazy lol. I'll check power to the fuse box today and update with what I find
IG: roadpirate
Old 02-12-2014, 08:49 PM   #4
S14.5patches
S14.5patches's Avatar
S14.5patches is an unknown quantity at this point
Check the harness under the wheel well and see if it has been eaten through has been known to cause problems.
just because you can, don't always mean you should.
S14.5patches is offline   Reply With Quote
Old 02-12-2014, 08:51 PM   #5
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
Also check all your dual filament bulbs like brake lights. They can cause very weird problems if the filaments burn together.
jorge1190 is offline   Reply With Quote
Old 02-12-2014, 09:40 PM   #6
Fuego
Fuego is an unknown quantity at this point
75a alt fuse.
Fuego is offline   Reply With Quote
Old 02-13-2014, 05:30 AM   #7
PW180SX
PW180SX's Avatar
Trader Rating: (32)
Thanks for the ideas guys, I'll check on them today!
IG: roadpirate
Old 02-13-2014, 07:56 PM   #8
PW180SX
PW180SX's Avatar
Trader Rating: (32)
Originally Posted by Fuego View Post
75a alt fuse.
You were correct. Fixed all my problems, thanks man!
IG: roadpirate
Old 02-13-2014, 08:26 PM   #9
Fuego
No worries, I had the exact same issue a couple months ago. Glad you got it fixed!
Old 02-21-2014, 04:14 PM   #10
TwoForDeh
TwoForDeh's Avatar
TwoForDeh is an unknown quantity at this point
i was reading through this and was literally about to say check the 75a fuse. when those little bastards go, everything fucks up.
TwoForDeh is offline   Reply With Quote
Old 02-23-2014, 10:58 AM   #11
PW180SX
PW180SX's Avatar
Trader Rating: (32)
Yeah, Glad I know now! I grabbed a bunch of them at the junkyard lol lol
IG: roadpirate
