You can use the lower auto harness you wont have reverse lights though. On my 96 thats how it was, you need a 5spd ecu though. You will throw a bunch of CEL's if you dont. I've got one if you need it.
#3 | |
![]() Join Date: Apr 2004
You can reuse the auto harness if have the connector with pigtail to the reverse sensor. Wire the reverse sensor to the body harness. |
#4 | |
![]() Join Date: Dec 2002
But think about your question. How does using a manual lower harness help you? The chassis is an automatic. So nothing you would need for a manual car will be found in the chassis wiring. Using a manual harness gains you absolutely nothing. Use what you have, hardwire as all the numerous writeups all over the internet tell you too.
