#211 | |
your guesstimates sound reasonable but I cant say with certainty. Keep in mind the 63 turbine wheel has almost the same inertia as the 58mm (due to the mixed flow blade tip design being inherently lightweight at the OD). The larger diameter 71mm compressor wheel is really where the majority of increased inertia comes from |
#212 |
![]() Join Date: Apr 2004
A v-band flange welded on a stock manifold sounds like an interesting bottom mount solution on a budget. It would take a lot of collector porting, and still have that stock SR tractor sound, but it'd allow you to clock the turbo on the v-band to where it'd fit with minimal fuss.
But it still seems like at this price point, ya might as well pony up for a quality twin scroll manifold like a Full-Race ( ) to get the most out of the turbo.
#214 | |||
#215 |
Geoff, when are you guys expecting the EFR 7163's with the forward facing compressor outlet? Hopefully it's not a 2-3 year thing to ramp up production... And are 7163s starting to roll in with more regularity? I've had to turn away a couple of guys who wanted a turbo in a few weeks and no 7163s were available.
![]() Forward facing compressor outlet like so: ![]()
#217 | |||
Dont forget the twinscroll 0.80 a/r EFR6758 is also available,thats a sick little turbo and with the same lightweight alloy center section as 7163 its not to be overlooked for a 430-450hp setup Quote:
FYI - dynochart attached of SR22 with twinscroll EFR7670, ve head w/ factory cams and uprated valve springs - thought you guys would be interested to see this one FYI#2 - a little OT but cool video, specifically 1:00 - 1:50: http://youtu.be/zyo_SwYm_K8?t=59s ^^Ford engineer explaining their re-design of the ecoboost cyl head for use with a twinscroll setup |
#220 | |
http://www.full-race.com/store/efr-t...-manifold.html these are both customers cars, neither is local, one with twinscroll 7163 and the other with twinscroll 6758 - both aluminum center sections I emailed the customer and suggested a longer inlet pipe, however he said he loves it and has no complaints or issues |
#221 |
I had no problems at all with a slightly shorter 3" pipe leading up to my Z32 MAF back before I ran a MAP setup. No issues at all with it.
The key with a MAF is to make sure you have a nice radius leading into the MAF adapter (think mini-bellmouth or velocity stack), and roughly 2-3 diameters minimum of straight pipe before you hit the element. More is better, but it works fine with this setup due to the inlet geometry approximating a venturi with the radius on the leading edge. A sharp leading edge on the MAF adapter will need more like 8-10 diameters to fully develop the flow field.
#223 | |
![]() someone is listening to me in my sleep.....
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected] Scott's Personal Website/Blog: http://www.scottandkerryann.com |
#224 |
![]() Join Date: Jul 2011
YES. I'm glad to see the quick spool valve finally made it into production.
I posted about it HERE on the first page of this thread over two years ago!
My S13 SR Street Mod Build |
#226 |
![]() Join Date: Jun 2011
I'm excited about the Quick spool valve as well.... and to see if it makes option for externally gated units as well.... That would be the perfect compromise IMO... The ALum Center housing is tits as well.... I'm always worried about heat... but this seems to be the answer...as long as it's strong enough that is. And lastly.. I didn't think these units could get any more user friendly.. But with a forward facing 90 Degree Charge outlet.... and lessened over-all weight with the alum center section.... I'm thinking this may be the ultimate upgraded Best performing turbo on the market. This is good!
IG:@AAPARKAH #ThisIsTheWolf |
#227 | |||
lol - I especially like this device becuase it converts from small AR singlescroll to large AR twinscroll. Better than the standard QSV's which are singlescroll onlyI agree that is a really neat compressor housing, it packages very nicely in longitudinal RWD applications. It is also going to be a 2016 release however As a group, everyone on the BW team is committed to constantly stepping things up and raising the bar. The VTV is definitely one of the more exciting changes, and we are always testing and trying new things to determine what will be next. Thanks for your input Aaron! really happy the twinscroll EFR has been trouble free for you |
#228 |
Geoff, will the VTV housing likely fit on a current B1 frame EFR of the correct turbine wheel dimensions with no mods once it's released? Looks like an interesting piece, and if you can update an earlier turbo it sounds like an interesting choice.
That said, for a track car it probably isn't a huge benefit since you're above the boost threshold 99+% of the time, so all you're worried about is transient response.
#229 |
Def - you are correct, the VTV housing will have less benefit on track cars which are operating above the VTV actuation range. If the flapper is going to be in twinscroll position anyway - then the standard twinscroll housing without vtv is the call. Keep in mind VTV is still a concept - all prototypes have been DLMS printed, not yet given the green light to start production with tooling, investment castings etc. I expect its 1 year away, starting to be for sale at SEMA next year.
Yes - The VTV housings are designed to be direct fits for existing EFR turbos, forwards and backwards compatible within the family.. the 6758, 7163 and 7670/8374 are the most popular turbos so we will continue to support them with future innovation |
#230 | |
![]() Join Date: Nov 2005
Saw the housing in person at PRI. Very cool stuff. The BorgWarner guys were really cool, answering some questions about compressor wheels I had always wondered about. Holding an inconel turbine vs a TiAl one is quite eye-opening, and it seems like the aluminum bearing housing is also going to be expanded to the entire lineup in 2016 as well. |
#232 | |
![]() Join Date: Oct 2007
I getting closer and closer to put my jb5858 for sale since its brand new And go for the 7163 Im running a doc race manifold with a v-band flange on it ... i know that flange works with pte and garrets turbo's !!! Would the efr 7163 v-band option work on my manifold or should i realy go twinscroll t4 |
#233 |
Yes - you can use vband EFR turbos on a manifold flanged for garrett/tial/precision but its not perfectly ideal:
![]() TiAL Sport / Turbo By Garrett vband on left, BorgWarner vband at right. Both have similar OD and use the same clamp however they differ internally at the ID diameter and valve seat. Soo the B1 EFR turbo can fit a tial/Garrett flanged manifold but is not perfect at the sealing surface. The tial/Garrett turbo will not fit A BW flanged manifold like the one shown here I personally think the difference twinscroll T4 makes on a turbo at this power/airflow level is is worth changing manifolds and eliminating the risk of a leak |
#234 |
Geoff,
Have you heard of any cars having fastener/gasket sealing issues on the T4 twin scroll housing and your hardware kit and heavy track usage? I imagine having things top mounted makes it significantly easier to keep things sealed up. I've seen you say that you don't like turbo braces (to the head/valve cover) before, do you still feel that way? I know your manifolds have a lifetime warranty to the original purchaser, but I'm trying to plan my next turbo/manifold setup, and I figure I might as well get all the pieces in place before pulling the trigger.
#235 |
Def - In my experience it takes a combination of 6 things to maintain a good long-term seal:
-spiralock threads in tool steel flanges, resists loosening during heating/cooling cycles -use a high quality stud/nut rated for the 'intermittent' temp -anti-vibration washers (heicolock or nordlock) -high temp anti-seize and tight hardware -a thick multi-layer steel gasket is superior to the standard single layer -Top mounting reduces the load on the studs to be certain. M10 studs are also much better at resisting deformation than M8 hardware -an alternative to antiseize if the car is an endurance racer is resbond (high temp thread locker) spiralock threads: https://www.youtube.com/watch?v=kLD8xP2k3_k anti vibration washers: http://www.youtube.com/watch?v=Pc53qDlvLTw |
#236 |
Hah! I had no idea you were there, otherwise I definitely would have.
BTW, if anyone wants a crazy deal on a used 6758, there is this one on ebay right now... http://www.ebay.com/itm/Borg-Warner-...0ab5d9&vxp=mtr ![]() |
#237 |
that is a used indycar turbo, be aware that it uses a different vband flange and clamp, a 3 bolt flanged input and doesnt carry any warranty but is definitely a sweet turbo
#238 | |
![]() ![]() I've really had issues with flanged turbine connections, so I still sometimes think that maybe a v-band connection would be superior to a twin scroll connection just because it'll stay tight. Yea, v-bands leak a small amount, but they're pretty foolproof on keeping stuff together.
#239 | ||
When targetting big power/boost without sacrificing response -- If its not twin turbo, its gotta be twinscroll IMHO |
#240 |
I typically don't post here, but since there is alot of speculation, I figure I would get the ball rolling. This is what I posted from another site
Update 6258 ~19psi dropping to 16psi by redline 180SX Blacktop (rebuilt to stock specs 20K miles ago) Sheetmetal intake S4 cams 3" Exhaust 3.692 rear end (yeah, long gears, I know!) 265-40-17 tires - Below is the graph comparison between Virtual Dyno (which I will be using as my baseline), Dyno Jet and Mustang Dyno. - Also, the A/F needs just a bit more tweaking in the spool region 3500 to 4800 RPM. YOu can most definitely see how rich it is in that regions and having two .4 drops, so will need to be smoothed over a little. - Only increased about 1 degree in the spool area (2500-4000 RPM) and lots more room to go! Plenty more room to help with spool there as well! Please forgive the sluggish boost response!!! - Redline timing is about 21 degrees. - In addition, there was a 1 knock count in the the spool region (around 3300 RPM. I pulled 1 degree, but it is either phantom knock or just rick knock) Also, this is with 8mm preload on the gate. No problems controlling the internal gate so far Virtual Dyno (318 WHP and 269 ft lbs) Mustang (302 WHP and 259 ft lbs) Dyno Jet (347 WHP and 294 ft lbs) All in all, fairly happy and this will be the baseline. Once I tweak the timing map for the spool region, I suspect full boost to be several hundred RPMS sooner and holding about 17-18 psi to redline. Also, the HP curve is STILL climbing at the end, so there is still a bit more power to be had it seems. I may or may not add more boost (may shoot for 22-24psi to see what happens), but I am very happy with the results and the car drives very well. |
