Idle ~400RPM unless AC is on
Just did new intake mani gaskets, and deleted PCV on my KA-T
All went well, no more boost leaks, however: - My car idles at like 3-400, and will idle higher if i kick the AC on. I checked the plugs on IACV and they are connected. What should I look at now? Could I just need to set the idle now that my leak is fixed?
![]() 5.3 V8 Swap w/ Nitrous |
Resolved, previous owner adjusted idle to compensate for the vaccuum leak. Now that I fixed it, I could adjust the idle again and all is well.
