93 Silvia K's Club, a purplish silver adventure
Hi guys, I recently imported this PS13 and figured I should do a better job of sharing photos and what I learn along the way so here's a thread about it! For photos but less words, try my instagram.
About the car, it's a 1993 Silvia K's Club with a pretty cool spec: -67,900KM / 42,000 miles -1K4 paint "purplish/silver" -SR20DET 5spd -Club package (digital climate control, triple projector headlamps) -ABS brakes -Sunroof -Aero bumpers -Viscous LSD ![]() ![]()
'93 Silvia K's Club Aero - 69K km - Instagram |
I miss stock s13's. Looks like a great base to start with. What are the plans?
#4 | |
me high hopes for the project, I wondered if the car dynod 185/185 at 10psi because it was tuned in a past life, but the ECU looks stock to me!
#6 | |
Spring 2020 Maintenance Repairs Fix seating position for 6'2" Low key mods that sharpen up the chassis (HLSD, springs, short shifter, etc) See how much power I can make with bolt ons and the stock T25, don't be slower than my wife's car Find some cool wheels so i can use today's best tires (225 and 17" smallest options in some cases) Summer/Fall 2020 Be able to do some open lapping and drive the car harder without parts/brakes giving up on me Find an OE-fit turbo (maybe GTX2867R) that supports about 300whp on pump gas but could make 350whp with cams and E85 if I ever decide to try later Don't ruin the car or cut up anything
Interior
Interior
Here's what wasn't working for me in the interior: -I don't fit well. My head hits the headliner, my knees interfere with the steering wheel, and the seat is too high. I added a 2" LTB Motorsport Nardi pattern steering wheel spacer in addition to the hub adapter and reduced the steering wheel diameter to 330mm. Everything is perfect except I need a lower seat with better side bolstering. I have no idea which seat to buy. -The radio didn't work, and I read JDM radios don't pick up the entire spectrum of FM frequencies anyway. I found there's a newer Sony receiver that has a built-in amplifier and outputs more than your average deck, 45w RMS instead of like 20w. Paired with new 6.5" speakers it sounds pretty good! Here's what I'm doing: Before ![]() After ![]() ![]()
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
I went through this a few years ago with my s13 hatch. I ended up modding some r32 gtr seats (i'm also 6'2") to sit lower in back and they were perfect for a street car. Z32 brakes f/r will be plenty, and s15 hlsd is a great call. Just need 5 lug for some 17x9s with 235-255s, and a Gtx2863.
The hard part at this point is finding decent suspension since most of the advanced DIY options are drying up. I'm local to you so feel free to PM me if you want to hit up some days or need a hand with anything. |
#11 | |
I'll probably end up upgrading to 5-lug for wheel options but interestingly my front brake rotors are already a step larger diameter than I thought, they're the same 280mm as Z32 rotors (ABS Silvia and 180sx) and I just put on some Hawk HPS 5.0 pads. I haven't driven them hard so I can't tell you if it's enough braking yet though. If you already have experience with the seats, LSD, GTX and all this, we should definitely talk - I sent you a message.
Trader Rating: (24)
I have a passenger s15 seat (well, your driver's side) if you wanted to try it out.
Welcome to swap it into your car and see if it works. I prefer the r32 seats but they're way harder to find in good shape as they're older. |
Any idea how much lower the s15 seats will be than s13 seats without modifying anything? My first idea was s14/s15 but I haven't read they would lower the driving position. This would be fantastic though to keep an OEM looking interior and to not spend $1500 on Recaros.
Clean ass car man, love that two tone it’s beautiful.
+1 for R32 seats, I’m 6’ 1” and have those in my S14. Fits way better and hugs your lumbar much nicer.
Dont be a pussy...Leave your name |
#15 | |
![]() Join Date: Apr 2002
the problem with S14 seats is that the car itself was meant to be more "luxurious", so the seats had more padding. It was definitely lower than S13 seats, but I think it was more of how the seat hugged you instead of making your back feel like shit. S15 padding was firm and the contour felt better overall. R32/33 seats were good but the age often made them inferior. S15 seats in S13: ![]() S14 vs S15: ![]() S13/14/15: ![]() |
Clutch & Exhaust
My clutch started slipping and although I didn't want to be pulling the transmission in the first 500 miles of ownership, I think it was my fault for switching to synthetic oil and exacerbating a rear main seal oil leak. I figured the turbine outlet would be easier to install with the transmission out, so I tackled exhaust too. Takeaways:
Parts:
Pictures ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Very Nice! I like your thoughts about how you want to progress with it!
You in Oregon? I'm out on the Westside, maybe I'll see you around!
1990 240SX SR20DET GTX2863R |
#19 |
June Update
I've gone through most of the entire car and refreshed/maintained it to a respectable state. I made a few mistakes with the incorrect mods and had to replace them a second time, but luckily everything is easy on these cars. What's been done recently:
What's next:
Please message me if you have a Bride MO seat rail for the right seat of an s13. ![]() ![]() ![]() ![]()
#21 |
I just ordered an s15 LSD yesterday after two months of waiting for Japan's shipping systems to return to normal. What's the going rate for an s15 transmission? I assume it needs some aftermarket adapters and a different driveshaft at the very least. Have you driven one?
