Likelihood of rotor damage in shipment?
I got a pair of brembo z32 rotors last week and the corner of box that they were shipped in was broken down the corner of it and the box that the bottom rotor was in was squnched up so they sent me a second pair today. The exterior box looked fine but the brembo boxes on the inside looked worse condition than the other ones did. These rotors have lot of dust on them and the ones had some type of lubricant on them. I'm wondering is it likely that they are warped. I still have the first set they sent so I could use either set. Just wondering if it's likely I'm going to have problems with them or not?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
z32 front brakes, spl tc rods |
#3 | |
Factory lube to protect them from rusting(I'd assume). Just hit them with brake cleaner before install and you're good. And don't worry about the smell/smoke after you "break" them in. It's just burn off from brake cleaner/etc.
Stop making these threads!!! Google or small questions thread or....search!!!!
yes i did a search on this question.
On other thing. The second set of rotors had a lot of dust on them but after removing it the surface was rough like fine grit sand paper where the first set was farily smooth and came in plastic. I'm surprised Brembo wouldn't be totally consistent in their packaging.
