RB25 clutch and pressure plate on SR20 question. What flywheel can I use?
What up good morning Zilvia.
I have searched but can't find a definitive answer.
I pulled the clutch and pressure plate out of my RB25 to upgrade to a stronger combo, and figured that this existing clutch would make a great replacement for my SR20 clutch that is slipping after last years drift season.
I know the RB25 clutch and pressure plate is 240mm, and is aka the 300zx NA clutch etc and the SR20 flywheel is 240mm as well. Can I use the existing OEM SR20 flywheel with the RB25 clutch and pressure plate? If not, what flywheel can I use on the SR that will work with the RB25 clutch?
Also what TOB \ Pilot bearing do I use on the SR tranny for this combo
