ok so the other day after i had put on a headgasket a week ago i noticed my on on light was coming on so i decided to just change the oil pressure sensor now the car wont start i have no spark the car was working fine before i put the sensor ive change the coil resently along with the rotor, and cap the dizzy i good cause im getting fuel in all cylinders just no spark, i tested the coil , primary has 1.0 ohms and the secondary has 12.5 k ohms so its seems to in spec. could it be my ignitor chip plz help need asap
dam im getting the same shit my guess was sumthin electrical so i pulled my body and engine harness to make sure theres no cuts and to my surprise there was mainly on the plugs that went to my dizzy
| no spark |
