#1 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
Sr20detman's Amazing For Sale Thread
Updated March 26, 2011 9:23am
Located:Oceanside and Orange County Selling my Nistune #62 Sr20det Redtop Ecu It was soldered professionally, It is working in perfect condition, Comes with Consult plug(not consult cable)(no software) $400obo Z32 OEM Tie Rod Inners Used for less then 6 months $50 Stock SR20DET Intake Manifold w/ Throttle Body and extras Comes with both Intake Manifold gaskets in good condition, and whatever in picture, No IACV $60obo Stock s13 Sr20det Mass Air Flow(MAF) Sensor $45 Hose Techniques 90 Degree 2.25" Brand New $15 Stock s13 Power Steering Low Pressure Hoses w/ Clamps Were bought new from dealer less than a year ago(Also might have cooling hardline for sale soon) $25 Stock s13 Sr20det Air Conditioning System parts I am missing the evaporator and 1 Line I believe, AC Bracket Sold - $75obo Greddy Style Manifold Throttle Cable Bracket for Sr20det RedtopThis one is rough i can clean it up to look nicer $20 Stock s13 Coupe Automatic Brown Seat Belt System w/ Ecu Rails, Belts minus driver belt, Ecu $60obo Stock s13 Hatchback Brown Rear Interior Trim pieces for 3 Point Seat Belts and A pillar $45obo Stock s13 Hatchback Brown Rear Interior Panels Arm Rest Pieces - $10 Stock Slave Cylinder Not sure if its KA or SR, or if that matters $5 SOHC Throttle Cable Not sure if it comes with bracket. $8 Stainless Steel Clutch Line Not sure if this is direct bolt on. $15 Stock SR20DET Oil Catch Can Not for Sale Stock SR20DET Turbo Line $5 Stock SR20DET Exhaust Manifold Heat Shield $15 Throw Out Bearing stuff $5 any other random part in that picture. $5 or less. Stock SR20DET Thermostat $5 Front s13 240sx Stock 24mm Sway Bar Energy Suspension Polyurethane Black Bushings $10 10 Gorilla Lug Nuts Close ended tuner 7/16 thread used with morosso studs #21173HT $15 Anything in this picture $5 s13 240sx Brand New Yamato Garage Rear Sway bar 27.5mmOne on Left, Just sway bar, No Bushings $95obo Front s13 240sx Stock 24mm Sway Bar. $15 s13 240sx Stock Cruise Control Unit. $5 (2)6x9 150w 40ohm Dual Illuminite speakers. $10 (2)235/40/17 Federal 595Camber Worn $20
![]() Quote:
#4 | |
bump #1
msglnthgsad
![]() Quote:
bump # 2
30 shipped is too low for the maf, ill do 45 shipped and the sway bar was pending sale today but i havent heard from the guy, so i will hit you up tonight ghost.
![]() Quote:
| cusco, nistune, redtop, sr20det, tie rod |
