BC Stage 2 S13 SR20det cams tomei and greddy cam gear
Used for 2 dyno sessions
tomei intake cam gear greddy exhaust cam gear Cams are stage 2 BC cams that have been WPC coated the marking you see on the cams are the wpc coat wearing in. cams were shimmed properly thus you notice the even wear across the lobe. 100 for EACH cam gear 250 for both cams will ship at your expense ![]() ![]() ![]() ![]() ![]() |
200 For the cams
150 for both cam gears 80 each |
bump it up. Also I should probably clarify. The cams are NOT being eaten up by the rocker arms.
The polished section of the cam is the cam surface being exposed once the wpc treatment is worn off. WPC is a micro metal treatment that fills the voids in porous metals . This increases strength while reducing friction and heat capacity. A lot of top name builders and race teams use this treatment process. You notice the cam lobe has an even surface exposure across the lobe which indicates that the rockers are properly shimmed. Where as if rockers were not properly shimmed you'd see one side of the lobe wear faster than the other side. So for clarification these cams are NOT damaged. Last edited by vvtisupra; 07-01-2010 at 04:47 PM.. |
Very interested in purchasing the Cam Gears. I have Tomei Pon Cams in my 2000 S15 SR. I am however running stock gears. Do you know if this will work with my cureent set up ? If so i am interested in buying tonight or tomorrow am.
- Drake- |
sorry guys these were sold a while ago
