![]() Join Date: Mar 2005
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
Stock SR T25 1/4 Mile Times
Just curious what other people are getting with the stock T25 on their SR20DET Cars.
Mine is an S13 SR20DET Redtop II in an S13 Coupe (full interior) running 14 psi on the stock T25 using falken street tires (FK-451's). A few minor mods like exhaust, intake, and bigger IC. 13.48 @ 104.1 mph with a crappy 2.111 second 60 Foot, on a poorly prepped track.
96 S14: Grip Track Car 90 R32: Bucket List Car 92 S13: Just for Fun Car Instagram: @SS.Maxey |
![]() Join Date: Aug 2006
i ran a 12.9 with greddy front mount,and intake manifold as for boltons. 2.2 60' alot depends on sea level and outside temp. 2.1 is a pretty decent 60' for street tires
time slip! that would be great! wish i kept mine. I ran a [email protected] MPH with the stock turbo in like the summer of 2002... good times.
Like Me on FaceBook !
Trader Rating: (28)
I know I could have run faster than a 13.4, I just didn't have enough time to give it a shot. My best trap was 105 mph, and I ran a 13.52 doing that. Oh well, next season, I'll be blowing those times away, lol.
Where are you guys shifting at?
My best was only like a 14.4 @ 98mph w/ a 2.4 60' or something like that. Also ran that time with both 7psi boost and 10psi boost. |
Trader Rating: (28)
For me
1st - 7000 2nd - 6500 3rs - 6000 I'm in fourth when I cross. I also launch around 3500.
#12 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
you should all be happy i have 2.6 60' all day long. and cant even break 14's someone donate me a lsd?
![]() Quote:
A decent driver should be able to pull 2.2s on decent street tires. Get a set of drag radials and run 1.8s. They say every .10 you cut off your 60, cuts .20 off your 1/4 mile time. Not far from the truth.
Friend of mine ran a 12.9 @ 108 with stock T25. S13 coupe. And he shifts way early. Like, he said he shifted at like 6k in 1st, so he can be in 2nd gear making some power under boost, and he shifts at like 6500rpm (T25 really chokes after that anyway).
::shrug:: I haven't tried that method yet. |
With my s13 hatch the best i could do until my cheap ass coupler blew was 13.9 with my [email protected] I only had an upgraded fuel pump, apex'i n1 exhaust, and a vlsd.. Given that was my first time at the track also.
![]() Join Date: Apr 2002
60'.... 2.209
330.. 5.997 1/8... [email protected] 1000' 11.708 1/4... [email protected] Backed that up with a [email protected] Thats with street tires, 14 psi, fmic, intake, exhaust and in florida meaning I was really close to sea level. I think I shift to slow or something. Do you guys "power shift" or just shift like normal? ie. letting off the gas when you push the clutch in..
89 S13 hatch/////98 Subaru 2.5RS |
#17 |
^^^ Are you who I think you are? If so... this is Data... the Asian guy w/ the flat black S13 hatch...
#18 | |
That trap speed is a little low . . usually 240's w/SR's trap around 105ish . . |
#19 |
His 60' is also not a 2.0 If it was a 2.0 then I can see how the trap speed might be 105mph ish.
My trap speed was only 98mph and running 10psi, and had a 2.3 and 2.4 60' |
#20 | |
Also, interestly enough, that same night I managed a 2.121 60'...but that ended up being a [email protected] might of had someone in the car with me on that run...I can't remember. Anyway, you guys have got me thinking that I could do a lot better without changing the car... hmmm
#21 |
Uh... I was there at the first OSW drift practice... umbrella... does that ring a bell?
#22 | |
#23 |
Zilvia.net GB Vendor
![]() Join Date: Apr 2006
Trader Rating: (65)
![]() ![]() ![]() ![]() ![]() Feedback Score: 65 reviews
91 s13 cp Sr20det Red top swap..jdm VLSD HKS EVC 12-13 psi stock t25, no cat,Full bolt ones..17 inch 5 zigens..13.2 shitty 2.1 60 fts..Trapping 110-111...why so bad?
#24 | |
I have been defeated.Oh well, I'm gonna go back to OSW with some friends hopefully when money isn't so tight, and crank it up to 14psi and see what I can do. |
#26 |
I ran 12.95 on my redtop hatch w/ BPU's (FMIC/3"/Boost controller @ 13 LBS. I was running bald 235/45 BF Goodrich G-Force Sports at 28PSI. 2.0 60 foot, no speed shifting, +100 degree track temps... the track was well prepped, though.
I'll see if I canm dig up those slips, it's been more than a year. |
#27 |
wat do you guys think i will hit at the 1/4 track? im in utah, have s13 black top sr20det, '90 fastback, full interior, vlsd, front mount, 3in. down pipe, no exhaust, yokohama street tires, 15 psi, stage 2 clutch, laucnh control, and other little stuff. i have beaten a 13 sec. turbo Si and my buddies rb25 powered s13 on the freeway pulls. this year will be the first year i run the sr at the track
#28 |
![]() Join Date: Feb 2007
i ran a 12.51 @ 111 with t25, greddy front mount, and full exhaust. i am running a tomei ecu but i dont know if that has any thing to do with it. but it might be the 1.68 60' i launch at 5k and it just leaves.
#29 | |
#30 |
1.6 are possible with drag radials and an lsd of some sort.
I used to run 1.90s with an open diff and drag radials way way back. Best was a [email protected] iirc. best ive ever hit was a 1.60 with (no 2 step) bf goodrich comp ta's and a t04b on a stock sr block/head etc. 2 step makes things easier but depending on routine servicing and condition of parts it can wear stuff out. good times. i think the mid 12s are thanks to very light cars (ie stripped or xe model's etc).
