#31 |
![]() Join Date: Jul 2006
My brake light acts like a shift light. comes on about 5500rpms. The tool that owned the car before me probably put a crap alternator in it, or the volt reg is going bad :hammer:
#32 |
![]() Join Date: Jan 2004
my headlights go up, but they dont go down. they also get stuck downsometimes and turn on without popping up.
![]() D-Street.net | bcuison.wordpress.com |
#34 |
my e-brake light and battery lights stay on since my last track day. so if you want to steal my car while the turbo timer is counting down you can for that couple of minutes or so then of course it shuts down. i probably should fix that.
joe |
#35 |
My HVAC only blows air on setting 4. 1,2, and 3 don't work. I recently replaced the little lights that light up the HVAC controls, prolly did something then, but don't really feel like opening it all up again.
#36 | |
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
#38 | |
NOW the car wont start, Fpump wont turn on with key...blabla. long story short cars gotta go/*shameless plug* |
#39 |
![]() Join Date: Sep 2002
Well lets see. My whole dash will randomly flick off for a split second every once in a while. The right headlight do some weird stuff. The right one is disconnected cuz it's possessed and I haven't diagnosed it yet. But the headlights come on for no particular reason every once in a while. At first it was only when it rained. Not when it was drying out and I hit puddle after puddle, but only when it rained. Not even the car wash did it. It would do it even if it just sprinkled enough to make the car look wet then stopped. Thats all I can think of for now.
= My day
#40 |
![]() Join Date: Sep 2004
all of the interior lights on the dash... i mean those on the hazard button, rear wiper, etc...
~小アレンのリベリオン~ いくせ, 勝負た! 轟こう, オレのKRMS13!!! オレの得意技!蹴り進入!角度の少ないドリフト! |
#41 | |
Good looking out. I'll look into it. ![]() |
#43 |
For most of the people with headlights not popping up and/or retracting, the problem is most likely your headlights switch is worn out. The same thing happened to me, a couple of years ago, the headlights started to hesitate before the would go down, and occasionally hesitate when going up. Finally, they stopped going down at all (though they would pop up fine). The problem was worn out contacts within the stalk of the headlight switch. You can diagnose it easily by looking which pins have continuity for each position in the FSM and checking with a multimeter, only takes about 10 minutes to test. I bought a replacement combination switch from Performance Nissan for ~$75, $50-60 cheaper than my local dealer.
#44 |
^^^thanks man, thats what I had it narrowed down too, ill see if it a new one works. New problems, every once in a while my wipers will randomly go on when start the car, or put the key in the on position.
#46 |
wow, so I replace my headlight stalk with a new "used" one. The plus side is now the headlights go up and down, but the highbeams dont work! Anyone know a fix for this, with my old stalk the high beams worked, is there a way I can take something from the old stalk and put it in the new one?
#47 |
I touched the + terminal on the starter to the block via a wrench, then sparks flew, and now my car only gets 3.5v between the battery cables.
Checked all the fuses and fusible links, they are all fine. The battery terminals show that the battery is still putting out 12.75v, and I even took it to Autozone and got the battery tested, and it came out fine. So basically, I got another main harness with fuse boxes and relays and all that to put into the car. Hopefully that will fix the problems. Prior to that though, I was messing with the HL retracting relay and crossed the wire, and I messed up the HL timer unit, so the HLs will only come up when I either use the button on the dash, or do a quick "high beam flash" for the lights to pop up. |
#48 | |
#50 | |
#51 |
![]() Join Date: Feb 2006
My radio and cluster clock stay on even when the key is off. I have to pull the fuse that controls them any time I park my car for more than 1 day. >_<
My clock only turns on when the headlights are off... Prolly something related to the wiring issue previously stated. Also... my HUD cluster likes to pick and choose when it will light up at night. Its not really a weird electrical gremlin, just a broken solder koint that occasionally joins or something like that, but I figured it was worth mentioning anyway. |
#52 |
my alarm goes off at random when i lock the car. guess it was just a bad alarm install..
i used to have a problem where the odometer would click the faster i drove the faster it would click. eventually my harness was rewired and the clicking went away |
#53 | |
Cluster clock is always on like that from the factory |
#54 |
![]() Join Date: Jul 2004
hmmm.
defroster light is out... i had a wierd problem where my pass side low beam would shut off when I put the high beams on... but then I punched the harness and it fixed it so idk... my right rear corner light kept burning out when I bought the car... no idea why... ended up cutting and splicing the wire and powering it from somewhere else.... nothing else I can think of... |
#56 |
S14-
Passenger tails only come on after you thump 'em (or drive a few miles)... but only first thing in the morning. After that they're fine Blower resistor blown, hi-fan Driver window auto down at slightest touch of switch, no 2-position anymore Airbag light blinkin, can't figure out the right resistor value to fool it... S13- Cluster doesn't work on cool damp mornings... then lights up nice as ever after you warm the car up. Tach always works Slow drain on the battery, sometimes 3 days, sometimes overnight, and not enough juice to turn over. Charges fine when driving, a 30 minute drive charges it right up... just drains when the car is off... E-fan never comes on, but not sure what temp it's set at.. or if it'll work at all with the SR harness. No AC anymore and no decent temp gauge yet... |
#57 |
![]() Join Date: Apr 2006
my only problem is that the greddy FATT stays turned on saying off and illuminated all the time.
other than that, nothing
2015 Subaru Outback Overlander - Wagonofdoom |
#59 | |
#60 | |
