In a bit of a delimma
So while cleaning up/tucking some wires in my engine bay i managed to some how tape up the signal wire to my starter.....
![]() If someone would be kind enough to describe a brief location on where wire is located and which connector it would be closest to that would really help a lot. Thanks! ![]() |
![]() Join Date: Jul 2013
the signal wire goes from the starter and through the lower harness and plugs in at the fuse box on the lowest plug. I am only referring to what i know on my s14 i just got not running and put a good engine and a 5spd in.
look at the under hood fuse box and look at the plugs that hang on the side of it and you will see the lower plug has a fat wire and a skinny wire
95 S14 se RB25DET 348whp
